I HAVE A YARDSWORKS MANUAL TIMER. I SET IT FOR 30, 40 50 MINUTES, IT DOESN'T MATTER HOW LONG. IT GOES ALL THE WAY DOWN TO APROX 15 MINUTES THEN STOPS TICKING, AND THE WATER WILL NOT SHUT OFF. IF I TAKE THE TIMER OFF THE CONNECTION AT THE HOUSE, AND JUST SET IT ON THE COUNTER, NOT ATTACHED TO ANYTHING, AND SET THE TIME TO 30, 40, 50 MINUTES, IT WILL START TO TICK, AND GO ALL THE WAY DOWN TO THE OFF POSITION. SHOULD I JUST TRY A NEW TIMER, OR WHAT?
SOURCE: switch not ticking after setting
Spring wound countdown timers turn on the load after dial is turned.
If your timer is not counting down, and turn knob is not rotating back to the start position, then timer is no good.
This timer counts down even if it's not connected to electricity, so the problem is not wiring.
SOURCE: grasslin timer doesn't display and it ticks
Grasslin Tactic timers have reset button as last step troubleshoot.
http://waterheatertimer.org/pdf/Grasslin-Tactic-371.pdf
Replacement timer is Tactic 771 Plus
http://waterheatertimer.org/pdf/Grasslin-Tactic_371_Plus_X20.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM
SOURCE: I have an ariston combi A boiler with a grasslin
Clock motor has gone bad.
Order replacement timer module:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#FM1
Usually the model number is on back of timer module.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: How to set time on Yardworks two zone water timer
Copy following link to access manuals for each brand of water timer on market 2013:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Yardworks does not have website, manuals or warranty claim procedure.
Instead, yardworks repackages other brands of timer, generally water timers, such as orbit or melnor and raindrip. And sometimes repackages other brands of outdoor timers.
Recommend folks stay away from timer-repackagers such as Yardworks, Timex, First Alert, and buy brand names that have clear customer resources.
