1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
There are many causes for this . could be battery or software of the phone.. whatever it is remove the battery of your phone and let it take rest for half an hour . try this , it can fix many solutionless problems. dont charge your phone for more than four hours
Find your solution from the list,
Nokia 6300
Codes:
Software & Hardware Problems
Find Solutions for other Nokia Phones:
Nokia N95
Nokia N73
Nokia N70
Nokia 6600
All the other Nokia Phones.
I had the SAME problem!
trust me, get a new charger,
that works 99% of the time.
I have had this problem with a Nokia 6230 total discharged battery. I solved it by flashing some voltage across the battery terminals.
My Nokia 6300 will not charge. I get no blue lights it just wont charge. I have 2 chargers and have tried both
My phone keeps freezing, turning off, and doesn't fully charge. I can't talk on the phone or do anything for that matter whilst it's on charge without it dying. The blue light sometimes comes on and the screen fades to black. It also takes at least 5 minutes or more to fully load. Whilst it's loading the screen is all white.
I had bought a new battery when the problem first started occurring, and it continued to do the same thing by not charging and dying. So that is not my problem. My original charger was a bit bent, but I use another one now, and I have tried charging with other chargers and the same problem of not being able to touch it whilst it's charging because it will freeze occurs. Also I can't leave the keypad locked whilst charging because then it will definitely freeze. The battery never use to fully charge, it would just continue to charge and charge, but it now tells me that it's fully charged, which is a good change, but it's still got a lot of problems.
Also some of my messages are being interfered by other messages. E.g.: Towards the end of a long message, the ending of one of the other messages in my inbox will be there instead of the original ending. So if I look for the start of the interference message, the ending of the original will be there. This also happens in my drafts. It's really annoying.
It's such a shame this phone is stuffing up, I really do love it. Does anyone else know of a phone with side lights that will flash when received a message or a phone call?
I had bought a new battery when the problem first started occurring, and it continued to do the same thing by not charging and dying. So that is not my problem. My original was a bit bent, but I use another one now, and I have tried charging with other chargers and the same problem of not being able to touch it whilst it's charging because it will freeze. Also I can't leave the keypad locked whilst charging because then it will definitely freeze. The battery never use to fully charge, it would just continue to charge and charge, but it now fully charges, which is a good change, but it's still got a lot of problems.
Also some of my messages are being interfered by other messages. E.g.: Towards the end of a long message, the ending of one of the other messages in my inbox will there instead of the original ending. So if I look for the start of the interference message, the ending of the original will be there. This also happens in my drafts. It's really annoying.
Also
annoying.
Well mine doesnt charge at all. I havent replaced the battery. I have bought the phone recently and I got a bit of charge when I first used it and then it ran out of charge and I cant charge it. I have bought a new charger and made no difference. When people look at the bottom of the phone, you have a hole with gold pins in it... How many are you seeing? Anyone else had this before?
Mines the same. All of a sudden, when I put my phone on charger, although the charging light came up, my phone wouldn't charge until it eventually died!!!
I've just bought a new battery and it isn't charging either... I've got two chargers, one is brand new and it also does the same, so its not the charger! Maybe its one of the connections, but I'm not sure how to get to the little pin at the bottom of the phone!
