Hi, Just bought a Oreck upro14T refurbished vac off amazon. Put it together-double-checked and triple checked-turned it on-stepped on release to clean carpet nd the brush roll goes a few rotations, then stops. Tried the troubleshooting-still does the same thing-on any service on any position. brush rolls goes a few turns then stops. All else is fine. What can be wrong?
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
SOURCE: oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
SOURCE: suction
Don't panic! Easy fix!
I was having the same problem, but I removed the base plate from the bottom of the vaccum (5 screws on mine), revealing the roller and the engine. Just behind the roller is an intake tube. Mine had a piece of wrapping paper stuck in it causing everything else to clog up.
SOURCE: stopped running
orecks have a plastic fan inside and everything you pick up hits it, sometimes things can get stuck in there or break the fan locking up the motor. With the machine off, poke around where the dirt goes into the motor, behind the roller and see if you can pull anything out.
SOURCE: how do I replace the brush roll on my oreck xl??
Turn the vacume upside down. Remove the 5 screws on the bottom plate. 3 are near the brush roll, and 2 are near the back. Remove the bottom plate. take the belt off the motor end. pull up on both ends of the brush roll. Put new brush roll on making sure that you put both ends to the new position, not old. ( it is marked on one end, and there are marks on the side that goes up so the can match.)(If putting back the old brush roll you can switch to the old position. After a year or two you can switch the new brush roll to the old position.) Put the bels back on the motor shaft and then stretch and start the belt on the brush roll and rotate the brushroll by hand untill the belt is all the way on.
put the bottom plate back on and tighten the 5 bottom screws.
