Http://vip.asus.com/forum/view.aspx?id=20081024173658250&board_id=1&model=P5K-E%2FWiFi-AP&page=1&SLanguage=en-us
http://howsolve.com/2011/09/how-to-solve-chassis-is-intruded-fatal-error-system-halted-problem/
HERE ARE A COUPLE SITES DESCRIBES CHASSIS INTRUDED.AND WHAT YOU POSSIBLE CAN DO ABOUT IT.READ IT CARFULY.
SOURCE: chassis intruded ? fatal error... system halted
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
SOURCE: How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
if this fails to fix the problem
Restart your computer during the boot process you will see a certain key to press to enter set up (BIOS) press and hold that key
Enter Bios
Go to Inter grated Peripherals
Go to Onboard I/O setup
Find "Chassis Opened warning"
Set to "Disable"
Press F10 to save and exit changes
Hope this helps
