HP Compaq Presario 2500LA Notebook Logo
Posted on Mar 22, 2009
I cannot connect with my laptop to my wireless network
I have problems with pfcontroller? the connecting with the wireless lan cardbus card (ieee 802.11b) doesnot work
certified for fcc part 15 class b
How to configure 4 Lan + 1 Printer +internet connections
If all your connections are wired, you can use one of the three following solutions.
1. Purchase a router with more then 4 LAN ports on it.
2. If the printer or any of the computers have a wireless network card, then purchase a wireless router and simply connect 4 LAN cables and 1 WLAN.
3. Purchase a hub. Connect 3 computers to the first 3 LAN ports on the router; connect the hub to the fourth LAN port and then connect the last computer and the printer to the hub. In essence both your computer and the printer will share the same IP address (the IP given to the hub) and they should work.
In any of these situations, connect the internet connection to the WAN port of your router.
Thanks,
Pat
1helpful
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
My drivers is working but cant get any network and icon says not connected checked my device manager and the driver is working properly
Hi, go back to the Device Manager, and "Update Drivers" using the ("Manual Option to install"). Next, choose the ("Let me choose driver software"), "install," and restart computer. "Did this soluton help?"
I cant connect to the internet through my wireless
I cant connect to the internet through my wireless but it sows connecton
2answers
Boost PCMCIA Wifi Card Range
em maybe you just need to change the pc card or honestly just change the pc for fast and efficient browsing.
2answers
Wireless card driver needed
Appreciate the direct "Ask Me".
To your concern, does it look something like the image belwo?
If yes, it is as you posted, a 802.11b Wireless LAN Cardbus Adapter distributed by GetNet Technology Co., Ltd. with model # GW-9106PC. Pls find driver and manual download from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Can't get wireless card to connect to router
Based on the error you posted, the network key you are trying to enter does not match the network key configured on your router. to make sure you get the correct network key, you will usually need to check it on the router configuration. I may be able to help you find that network key if you can provide me the brand and model number of your router.
Wireless connection
before you insert the card to the slot run the cd thats comes with it and install the software. after installation of the software insert the card. if it is properly installed, you will see a single computer icon on your task bar click it up and search for a network.
Wireless cardbus pc card tew -601 pc
Hi..thanks for ur suggestion..my problem has been solved by opening my computer - properties - hardware and clicking on device manager and thr other device showing yellow question mark and i thought wirelss device doesnt work properly and i cliked on update device..a nd now my pcmcia card works fine
Thanking you
Neethan
2answers
Network card
Any type of PCMCIA network card should work okay.
Go down to Staples, Best Buy or Office Depot and find
a decent PCMCIA network card.  You should be able to find
one for under $50
Mike
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
