My natural gas pool heater is not igniting. The Ignition Control Module LED Flashes 3 times during initial ignition which indicates on the Ignition Control Module panel "Ignition Lockout". What is the solution? I have gas flow, and no other LED's @ the heater touch control are ON. Thanks
SOURCE: pool heater
If the heater fails to ignite after three attempts, the heater will automatically go into Lock Out. This is a safety feature on the heater.
Things for you to look at to see what is causing the problem are the display panel and diagnostic lights. When you turn on the heater, is it reading the correct water temp? If not, the Thermister has gone bad and will need to be replaced. When you try to start the heater, is there an Error Code displayed? Which of the Service Lights are coming on when the heater will not light? If it is the Serivce System, that is usually low flow of water. You may have a dirty filter, skimmer or pump basket full of debris, or a valve not completely open.
If the Service System light is the one coming on, then you will need to take off the top two halves of the heater and turn over the Display Panel. There are diagnostic lights on the back side of the panel. There may be a red light next to any of the following:
AGS, AFS, SFS, HLS, PS or THERMISTOR
If there is a red light next to one of these, then that is what has malfunctioned. If you need an Owner's Manual for the heater, you can find one online at the following link:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
Try the owners manual for these pool heaters. They have a detailed troubleshooting guide that should let you know what you need to do.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
SOURCE: I have a STARITE SR333NA
It has a bad thermocouple, that reads the flame, it needs replaced.
SOURCE: igniter lockout based on led flashing 3 times. I
This issuesounds tricky. I recommend you call the Sta Rite technical support at888-782-7483 and they should be able to help you figure this issue out.
I hopethis helps.
