Question about Intuit QuickBooks: Pro 2005 for PC
I can't load quick book 05' I keep getting the same error.
I am using Vista, durring installation the program says I need to load flash player 7, I continue to get the following error even after I install the recommended program:
Error Installing Flash 7
Cannot install "Flash Player 7" from "D:\ThirdParty\Flash7\install_flash_player_7.msi".
Please go to "http://www.macromedia.com/software/flashplayer" to download and install "Flash Player 7", and then run the QuickBooks installation program again.[Error:1603]
Help!
Mike
  • Anonymous Apr 06, 2009
    Still the same error. I downloaded Flash 10 the way you recommended. even tried to load flash 7. Any other suggestions?
    Thanks,
  • 111 Answers
- close all programs
- use internet explorer to open http://www.adobe.com/products/flashplayer/ - download and install flash player.
- run quick book 05 installation again
Posted on Mar 22, 2009
6ya staff
SOURCE:
No wireless
I see.. Just go to the manufacturer's page ..select teh model and download all drivers for this model and windows 7 ..usually if they are not there you can use the vista drivers but select them in the properties to run in compatibility with visa if they make issues..
About the programs ..it probably was a human error ..cause you do not payed attention on the selections made when you installed it ..You should specified to keep files and programs if possible ..and if you did and it made this ..it means it was no other way ..
Anyway ..there are alternatives for the programs in windows 7 ..and the drivers need to be installed manually ..
The other programs too ..just download them and install ..cause the usual ones like players and so ..are freeware ..
if you use HP ..like it is said here ...the link will get you to the support site ..
http://www8.hp.com/us/en/support-drivers.html
Dec 18, 2011 | Compaq Presario 5000 PC Desktop
I'm running windows 7 on a Toshiba L455 and I keep getting a prompt that says; can not find "flash.ocx"
Flash is a programming language that many publishers use to create animations, games, and interactive programs for the web. Flash is also used for programs run locally on a users computer. To use these Flash based programs and web applets, the end-user must have Flash Player installed. One component of Flash Player is a file called "flash.ocx." If this file is missing or damaged, you may get an error message.
There seems to be two root causes of this error. A description and solution for each follows:
  • You receive the error message "Cannot find the file flash.ocx" every time you start your computer or each time you open your web browser (such as Internet Explorer). This is usually the result of a missing "flash.ocx" file caused by an incomplete installation of Flash. Here's how to remedy the problem:
    1. Download the Flash Player uninstallrom Macromedia. Save it somewhere convenient.
    2. Run the downloaded program and allow it to finish.
    3. Once the uninstall completes, restart your computer.
    4. Visit the Flash Player website and download/install the latest Flash Player version.
    5. That's it!
  • You receive the error message "Cannot find the file flash.ocx" at seemingly random intervals or when starting a specific program (other than your web browser). First, perform steps 1-4 of the previous solution. This will insure you have the latest version of Flash Player installed. If you still receive the error message, continue with the steps below:
    1. Navigate to the folder "C:\WINDOWS\system32\Macromed\Flash\". In this folder you will see a file named "Flash9f.ocx".
    2. Make copy of the "Flash9f.ocx" file in the same folder as the original (copy the original, then paste the copied file into the same folder).
    3. Rename the newly made copy to "Flash.ocx".
    4. If the previous steps don't eradicate the error messages, change your screen saver to one of the defaults that are included with Windows (such as "3D Text").
if the problem still persist please let me know.
Apr 15, 2011 | Computers & Internet
I tried re-installing flash player and all the settings are in order, but farmville keeps giving a black screen...?
Try this
1. Uninstall Flash Player using the Flash Player Uninstaller - click here
2. Download the reset_fp10.zip file and extract the reset_fp10.cmd file to the directory C:\ - click here
3. Download and install the Subinacl tool to the C:\ drive (By default it installs in C:\Program Files\Windows Resource Kits\Tools\ but if you install it in that location it will not recognize the subinacl program even if the reset_fp10.cmd is in the same location)- click here
4. *Important: Be sure that both the subinacl.exe and reset_fp10.cmd files are in the same location.
5.
In Windows Vista and Windows 7, launch command prompt (Run as Administrator) and go to C:\. Type "reset_fp10.cmd".A command window will open, and SubInACL will run.
6.
Do not use the machine while SubInACL is running.
7.
After SubInACL finishes, you will see a prompt "Press any key to continue".
8.
Download Flash Player 9 Activex - click here
9. Install the Flash Player- click here / or download from www.adobe.com/go/getflashplayer
These procedures worked on my friend's PC, hope asme goes to yours. Goodluck!
Mar 28, 2011 | Facebook Social Network
My igolf neo won't work with Windows 7 if i try
I fixed this problem by going to Start>Control Panel and uninstalling the Java 64-bit program. It is incompatible with the Neo sync application. The other Java program on there is compatible. It worked immediately without even restarting. (I tried the above Best Solution, but on the newer computers, I get a message saying the Vista driver is only for Vista, not for Windows 7).
Jan 30, 2010 | NEO iGolf neo MP3 Player
Everytime i keep trying to load yoville on my fb a/c it wont load up at all i keep getting "stack overflow :126" but i created an a/c for my daughter and yoville loading straight up for her and i wondered...
It's probably a browser or windows error if using IE - try using firefox or a different browser. Yoville also has occasional loading problems that generally get fixed fairly quickly. Stack overflow means the program has run out of memory space to store parameters to - the solution to this would be to clear your browser and try login again. ( Internet options for IE or clear private data on firefox), then restart your windows. It also is possibly a java script error - you can update java for IE at http://www.java.com/en/download/index.jsp
To fix IE6, usually there is a check box in add/remove programs, windows components, uncheck it, then recheck it and it will install IE again. If using IE6SP1, it will possibly be listed as a program in add/remove programs, simply click uninstall and it will then offer a repair or restore option, use repair. Restart is required. If using IE8, try going back to IE7, uninstalling will revert back to the 7 version. The 7 version works far better than 8. You might also try updating your flash player if the problem persists.
Oct 02, 2009 | Facebook Social Network
Error when trying to download MS strrets and trips 2006 w/ GPS lo
I have used every version of streets & Trips since 05, and have never had any issue with Win Media Player, currently using streets 2009 on one machine with Windows 7 RC1, which has WMP 11, and on another PC streets 2008 and Vista with WMP 11. You may need to change your default program settings for media back to WMP if you ever had another media player installed.
Jun 13, 2009 | Microsoft Streets & Trips GPS 2006 x GPS...
I am using windows vista. now i want to install quick book 2005 but error exits please first install flash player 7. when i go to install flash player 7. it not support my operating system vista. pla guide...
You probably don't need to install version 7, i'd try installing the latest version instead.
There might also be a install patch on the intuit website or some kind of workaround.
If not it might just be easier to buy a new copy.
Feb 23, 2009 | Intuit QuickBooks: Pro 2005 for PC
Problem installing quickbooks pro 2005 software
right click on the install cd and click on QBooks, then setup and it will install withou tthat happening
Jan 31, 2009 | Intuit QuickBooks: Pro 2005 for PC
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
Intuit QuickBooks: Pro 2005 for PC Logo
554 people viewed this question
Top Intuit Computers & Internet Experts
NET MAN
Level 1 Expert
Ekse
Dalynn Turner
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
