Re: automaticaly closed my nokia n73 memory card...
Kindly update your nokia phone through nokia software updater .. http://www.nokia.co.in/get-support-and-software/download-software/device-software-update/download
The memory card slot for Nokia N73 is located at the bottom of the keypad just above the charger connector.
Before you eject the card, press the power key, and select Remove mem. card. All applications are closed.
When Remove memory card and press 'OK' is displayed, open the door of the memory card slot.
Press the memory card to release it from the slot.
Do not remove the memory card in the middle of an operation when the card is being accessed. Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
remove your memory card if there is any, and follow the following steps.
but before, do you have any contacts saved on the phone memory, if yes, first back them up onto your memory card. go> contacts >options> copy all > memory card. after backing up contacts, - power off mobile - press *,3 and call button all at same time and power up mobile. - keep pressing the three buttons for about 2minutes -release them and wait for mobile to start full. - Your problem should be solved - put back memory card and restore your contacts.
Hey there actually i also had the same problem but a minute ago so a review in the site http://cdpsolutions.blogspot.com/search/label/Nokia%20N73 and it said that formatting my cell with the number *#7370# would help if no try doing the other way of formatting that is : switch off your mobile phone and simultaneously press 3 keys that is green dial, star key (*), and no.3 key while pressing all these key switch on your mobile the factory settings will be restored or as to say your phone will be fresh as new, JUST DO REMEMBER TO TAKE A BACK UP OF ALL YOUR REQUIRED DATA because mine got deleted few minutes ago. hope this works, take care gob bless bye
try this...it worked!!!!!!!!!!!!!!!!!!!! take a backup of all u need n memory card... remove memory card from the cell go to lifeblog application then mark all and delete them... then put back memory card and check it!!!!!!!!!!!!!!1 the lifeblog application eats up memory
Try removing your memory card and then using the phone.
If this solves the problem, then might be your phone is unable to deal with the amount of data stored on your memory card.
OR
Remove applications like 'FS caller' and applications that eat resources of your phone.
