Anonymous Posted on Jun 06, 2013
How do I disable HP ToolboxFX error alerts
When I try to use my printer ( CP1525NW ) Laser Jet HP printer I get a Toolbox FX error alert and says " HP Toolbox FX has encountered an error and cannot recover. How do I disable this or fix this problem. I am using a Samsung laptop OP Windows 7 32NT-6.1.7601.65536 HP Toolbox version 006.007.00770
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jun 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3192
Points
12
How about installing a new laser jet HP printer tool box fx...
4 Related Answers
steve shroder
  • 141 Answers
  • Posted on Sep 17, 2008
SOURCE: I am not able to install toolbox of HP laser Jet 1320
bad disk.
Anonymous
  • 1110 Answers
  • Posted on Jan 05, 2010
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Testimonial: "It worked. Thanks. I' just FIXYA again"
Anonymous
  • 2785 Answers
  • Posted on Aug 05, 2010
SOURCE: HP ToolboxFX has encountered an
plz try by reistalling the software
Anonymous
  • 31 Answers
  • Posted on Aug 10, 2010
SOURCE: I have a HP LAserJEt
This is an official known issue by HP. Call HP Tech Support (800 334 5144 )and claim your warranty. Good customer service!
Hp laser jet cp1525nw false paper jam
All I can say is check the paper Jam sensor for particles of paper that it is sensing as a jam.
How do I disable my HP Toolbox FX error alerts on Windows 7 when I use my Laser Jet HP printer that is connected wireless to my Samsung laptop
Toolbox is NOT supported in Windows 7 To disable,
  1. Use the Windows Search feature to find the hptlbxfx.exe
    application. Typically, this executable file is found in the following location:
    C:\Program Files\HP\ToolboxFX\bin
  2. Click Start .
  3. Click Run .
  4. Browse to the location of the application, or type the path. Do not click OK .
  5. Add the disabling option by typing -disable
    at the end of the path. The information in the Open field will appear as follows:
    "C:\Program Files\HP\ToolboxFX\bin\hptlbxfx.exe -disable"
  6. Click OK .
I get an error message when I scan. It says Error
ISSUE: The error Waiting for PC is displayed on the control panel when scanning, using the Start Scanbutton on the control panel. The user will also notice a Not Setup on PC error when pressing theScan to … button. Note that scan from the PC works properly without an error. SOLUTION: The probable causes for this issue are listed below:
  • Firewall denying access to PC
  • Device polling not enabled
  • The scan to function is not enabled in the HP Toolbox
  • The destination has not been added to the Scan to button from HP toolbox
  • The HP Toolbox is losing the scan to destination
How to troubleshoot this issue:
  1. PC protection software such as firewall software may prohibit proper communication between HP AiO products and Toolbox and scanning software. Firewalls may need to be reconfigured to allow Toolbox to communicate with the AiO. The Toolbox software is similar to Microsoft Outlook and Internet Explorer in this way. Temporarily disabling firewall software may be helpful in determining if it needs to be reconfigured for Toolbox to operate properly. Please contact your third party firewall software vendor if assistance is needed to reconfigure the firewall. The following third party support Web sites may be useful:
  2. When Device Polling is turned off, the Alerts and the Scan to e-mail or folder options in the HP Toolbox are disabled, and the START SCAN function on the HP LaserJet AiO product control panel is also turned off. CLICK HERE for instructions on how to turn on Device polling.
  3. To program the device SCAN TO ... button, view the device settings. Open the HP Toolbox and click the Scan to tab. For more information, CLICK HERE to view the document titled HP Color LaserJet 2840 AiO Series Products - How to use "Scan To E-mail" or "Scan to Folder" from the Device
  4. The User loses the folder when choosing to save scanned files under the Scan to Folderoption of the Scan to Tab. The User also may lose the email settings under the Scan to Emailoption of the Scan to Tab. The User restarts the toolbox and it works for some time and the problem repeats again. Perform the following in the order listed to resolve this issue:
    1. Run the Fix Scan Utility and see if it resolves the problem. Click here for the Fix Scan Utility at http://www.hp.com If not, proceed to the next step.
    2. Check the firmware version and make sure that it is up to date. print a configuration page to see what the current firmware version is. Compare it to the latest version offered on HP.com Click here for HP.com at http://www.hp.com . If it is not the latest version then upgrade it to the latest version available on the web.
    3. Download the Software Update Version 3.0 from HP.com and install it. Click here to download the software update from http://www.hp.com
  5. For Toolbox Reset Persistent Data issues, CLICK HERE to view the document titled HP Color LaserJet 2800 All-in-One series - Toolbox Reset Persistent Data
  6. If the issue persists, uninstall and reinstall the printer software. CLICK HERE to view the document titled HP LaserJet 2820 and 2840 AiO Series Products - Uninstalling or Removing the Printing Software and Shared Components
I have lost my manual for the hp laser jet i need step by step instructions on how to change the speed dial numbers
Here is the Technical Reference Manual for your Printer. As you can see below, your add numers to the Fax Phone Book, within the HP ToolBoxFX.
GOOD LUCK
Fax Phone Book
Figure 2-42 Fax Phone Book screen
Use the Fax Phone Book screen to add and remove individuals or groups on your speed-dial list, import
phone books from a variety of sources, and update and maintain your contact list.
Hello,my hp laser jet 1320 does not work correctly,I work under an office network, some time it prints and some time does not print specially about pdf files or high size files, the alert is: fail to...
Is there a typical application you are using? I noticed that file size (especially in adobe) can be an issue. If you go to printer settings (start / settings / printers / right click on the 1320 and select properties) choose device settings and the very bottom item is printer memory. I would increase this to like 80mb.... hope this helps
2helpful
2answers
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
k24674
ADMIN Andrew
ADMIN Andrew
