I get VERY scratchy reception on channel 2 (VHF), all other channels OK and cable is ok. Picture is visable but snowy, volumne is scratchy.
What would be causing this?
I tried a different TV on the same cable as is feeding the TV with scratchy channel 2. The different TV is perfectly clear, no snow , no scratching.
What;s up with that??I tried a different TV on the same cable as is feeding the TV with scratchy channel 2. The different TV is perfectly clear, no snow , no scratching.
You can't post conmments that contain an email address.
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
digital signals do not fade out and get snowy like signals used to do ... if the signal gets too weak then it just freezes .. you might say its either perfect or frozen .. sometimes it gets blocky .. where some sections of the screen freeze while other sections continue .. what that means if you are using an antenna is .. you need a better antenna or better aim for the one you have .. outside is much better than inside but just rabbit ears are ok for strong signal areas .. you can aim the antenna based on a signal strength meter usually provided in HD receivers in the setup menu .. you can also get an antenna map from "www.antennaweb.org" .. that will show you what direction to point the thing for each channel and how strong each channel should be ... if you are using Cable instead of an antenna then you should have good signal strength but there is a problem called "Crest Factor" .. that becomes an issue when they put too many signals on a given cable .. the cable handles it ok as long as there is no damage (bad ends, water inside, animal chews, corrosion) but the cable box or receiver may be overloaded as thousands of signals drift in and out of phase ... thats a cable company problem that might be getting worse as more channels are added .. the results are that periodically the picture will freeze or pixelate .. you probably have to accept a little of that but more than a little gets really irritating ....off the air reception with an inside antenna (like rabbit ears) you will find that moving around the room can effect the signal for channels in the UHF range (most are) .. aiming the antenna and getting it as high as possible will minimize that problem.. make sure whatever antenna you use is designed for UHF as well as VHF .. the little circle often found between the two "rabbit ears" is actually the UHF part of the antenna .. it can be rotated for UHF channels while the big ears are aimed and adjusted for VHF .. antennaweb.org will tell you which is UHF and VHF ..
Use an Antenna that Provides Good Reception of All Channels
Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
Ensure that your components are plugged in and have their power turned on.
If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
“Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
First of all check if theSatellite box or the RCA cable is working ok with other equipment/TV if they both r working fine then their is an internal problem with ur TV.Show it to a authorised service person.
If you can see white, then all the CRTs are functioning. Make sure that the channel is set correctly. If the DVD is sending out channel 3 and the TV is set to channel 4, you will see the picture, but in B&W, Check that first. Let me know if that does not resolve it.
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Channel reception lost if tuner socket moved
Dry joints on IC522, IC521 and IC541 (located in the big heatsink about middle of the main pcb)
It is hooked up to Direct TV. When I change the channel on the TV to another input it looks fine but without a picture.
as you do not see tint in another channel means your color section is ok
it is due to video or luminance section.
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
