Fedders AED24E7F Wall/Window Air Conditioner Logo
Posted on Mar 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ptac heating problem
I have a ptac the a/c works fine
the heat barely works
it was "repaired" about 2 years ago
now the same problem,with heat in
high,thermostat up all the way
it seems to barely heat up the room
it is cool,tepid at best
it is a friedrich model thc12k34stc
other number lkkp01139
it's about 8 years old
the thermostat was replaced already
it there a flow chart or checkable part or fuse?
thanks
Donni Steen
Level 3:
  • Master 687 Answers
  • Posted on Mar 22, 2009
Donni Steen
Master
Level 3:
Answers
687
Questions
0
Helped
446411
Points
2142
This is the service manual for this system. It might give you an idea on what the problem could be. Page 27 should be your area to start. There are two for the PTAC series. I'm not sure which one will pertain to you.
http://www.friedrich.com/downloads/PTAC_Service_P-Series.pdf
http://www.friedrich.com/downloads/PTAC_Service_PD-Series.pdf
Amana DigiSmart PTH153B50AM 14000 BTU Heat Pump. What Amana model replaces PTH153B50AM please?
Question edited for a lot more clarity.
The new improved energy efficient versions.
The Improved Amana R-410A PTAC Unit Uses Less Energy
Amana PTAC https://www.amana-ptac.com > products > ptac
Looking to buy an energy-efficient PTAC unit for your building? Buy the new Amana R-410A PTAC unit heat pump, which reduces energy consumption by 35%.
Probably this one. Talk to your installer.
https://www.amana-ptac.com/products/ptac/hec154j
PTAC Blows Cold Air in Heating Mode when it reaches -3F less than the Set Value on the Thermostat - Model: AZ65H15DABW6
It sounds like your PTAC (packaged terminal air conditioner) unit is malfunctioning. When the thermostat is set to heating mode, the PTAC should be blowing warm air, not cold air. There are a few possible causes for this issue:
  1. The PTAC may be low on refrigerant. If the unit is low on refrigerant, it may not be able to properly heat the air.
  2. The PTAC's reversing valve may be stuck in the cooling position. The reversing valve is responsible for switching the flow of refrigerant between heating and cooling mode. If it is stuck in the cooling position, the PTAC will blow cold air even when the thermostat is set to heating mode.
  3. The PTAC's heating element may be malfunctioning. If the heating element is not functioning properly, the PTAC will not be able to heat the air.
I recommend contacting a trained HVAC technician to diagnose and fix the issue with your PTAC. They will be able to determine the cause of the problem and repair it properly.
1helpful
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
Hammering sound ptac
heat pump? possible causes: low freon. clogged / dirty coils. blower motor running?
16helpful
Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
