Car Audio & Video Logo
Anonymous Posted on Mar 22, 2009
Fm Radio pops but every other mode works fine
The fm radio pops loudly while trying to listen to the radio but the rest of the modes work fine Ive checked my conections and the antenna conection is fine
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
59
Points
Found a broken antenna wire
My radio has recently started to go into seek mode on it's own and I can't stop it when it starts.
New HD Radio Applications Seek to Fix System Flaws ...
diymedia.net/new-hd-radio-applications-seek-to-fix-system.../7560
Jun 22, 2015 - ... Asia, and elsewhere: instead of every station having its owntransmission ... Nautel is bringing the same concept to FM-HD as part of its "HD ... Ismy radio broken? ... Inovonics expects to go into full-production mode on the Justin 808 in ... As it has been for the entirety of HD Radio's history, I guess it'll be ...
Troubleshoot problems with radio stations in Windows ...
windows.microsoft.com/.../troubleshoot-problems-wi...
Microsoft WindowsLearn about solving problems with trying to play FM radio stations in Windows Media Center. ... Why doesn't my FM radio play? FM radio may not play for one of ...
2answers
How can I get my midland 9001z from AM to FM
Hi Trevor,
The Midland radio you have is NOT capable of FM transmit & receive. It is a Citizen's Band radio that operates on channels 1 thru 40 that are assigned to the 26.965-27.405 MHz frequency range. These are the standard 40 Ch CB frequencies in the U.S. (and may not be legal for use in other parts of the world without a license from your country's communications authorities). It also offers Weather Band reception - again these are US frequencies that may or may not even be used at all in the UK. Since the radio only displays a channel number, you don't actually know the frequency you're monitoring or transmitting on. Your friends on CH 5 may be in a completely different band.
Even if they are on the same frequency, the fact that they are operating in FM mode means that you would hear something - but it may not be intelligible - and the same would be for them listening to you transmit in AM mode. If you could have them switch their radio to AM, all would be fine. I suspect they use FM as there is much less static when compared to AM.
If they won't change to FM, you'll either have to stop trying to talk to them or buy a radio capable of FM (and make sure it has the same frequencies as theirs!).
Problem with Superstar 3900 CB Radio
did you found the problem,mine has the sam problems...reception not very loud on ssb,am fm very good...
2answers
Can i listen to fm radio without using earphones?
It will be depends on your mobile brand....
Jun 30, 2011 • Cell Phones
How do you access the fm radio on a Samsung GT-C3300K please. The user manual only mentions the mp3 player. Thank you.
To listen to the FM radio
1. In Menu mode, select FM radio.
2. Select to start the FM radio.
3. Select Yes to start automatic tuning.
The radio scans and saves available stations
automatically.
The first time you turn on the FM radio, you will be
prompted to start automatic tuning.
4. Control the FM radio using the following icons
and keys:
You can find the User Manual that show the FM Radio in this link. Look on Page 25 for the Radio Instructions
6helpful
2answers
Loud Speker Not working in Radio FM in LG KU990 VIEWTY
unfortunately, this option is not available on viewtys, however - if you bring up your phones keypad and dial 3845#*990# (don't press the call button after) you'll be presented with test mode, use the cameras jog wheel to scroll down to FM Radio test. Now, if you're lucky - you'll find a VERY strong radio signal that the viewty can pick up without the headphones in, and it'll play it through the speaker. But otherwise, you have to have the headset in to get a good signal, and if you have the headset in, there's no option what so ever to divert the radio to the speaker. So Sorry, but the radio can only play through your headphones unless you're lucky with test mode. (press the "C" button when in test mode to return to the home screen)
1helpful
Radio Shack PRO-96 What mode do I use for scanning==866.600 to 868.450 range and 44.82 to 155.175. The choices are== AM Mode (AM) FM/Digital (FM) CTCSS Mode (CT) DCS Mode (Dc) Motorola/APCO-25 Trunking...
You more than likely want the FM mode. If you are listening to a trunked agency then you will have to know if they are on the MOT, or EDACS system and choose the correct one.
Music mode screen is frozen after listening to FM radio
press the middle button and the power button for q0 seconds
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Dewalt radio. no fm signal
did you try replacing AA abttery at the battery compartment.if it is still not working the display board is cappot
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
