After I changed my spark plugs now smoke is coming from from where the spark plugs are...? It's white smoke and its a burning smell not sweet..
I can't see the smoke you're talking about - but I suspect it is oil burning off. Did you see / apply any oil to either the threads of the block or plugs or drip or spill something on the exhaust manifold / pipe? Did you torque the spark plugs in properly? A loose plug can result in poor compression and ignition and allow some exhaust gasses / smoke to escape. The engine sounds to be running well, so I suspect that the small amount of oil burning will be burnt off completely very shortly.
With or without the motor running? See if there is a difference.
