I need helpppppppppthamks.
SOURCE: dvd wont play in mini hi fi system
First, you should never use commercial cleaners on CDs or cassette heads. They can create more problems than cures.
Unit may have bad disk motor or optical pick-up
SOURCE: Panasonic SC-AK750 Mini hifi
The problem is usually either the amp-pac or a regulator. If the problem is the amp-pac, expect to pay around $90 or so for the part alone. The regulator is much less. Yes the unit is repairable, but get an estimate on the cost as some of the newer units may be close to that cost as a replacement.
Dan
SOURCE: Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
SOURCE: I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
SOURCE: SC-AK78 CD Shelf System: MY PANASONIC MINI SOEREO SYSTEM SHUTS OFF WHEN I T...
STK-470-040 ic is blown and needs to be changed.
