Question about Whirlpool Duet GHW9150P Front Load Washer
What does the "sud" message mean?
For a while I was getting the F02 error. Now I get the "sud" message. The machine drains and spins out, but not every time. The F02 message happens when I have it set on high speed spin. I get the "sud" message when I place it on medium speed spin. Help?
  • Whirlpool Master
  • 1,527 Answers
Hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Posted on Mar 22, 2009
6ya staff
SOURCE:
My Maytag Front Loader Washer was reading sud on the digital screen and also reading F02. After a few days past by, it stopped reading that because i looked online and thought i solved the problem. Just...
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Maytag EPIC MFW9700S Front Load Washer
At the end of the normal wash cycle my washer begins to beep repetitively and shows an error code of F 02?. It will not spin and drain. We've began to switch it to Drain/Spin cycle and this works about...
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 30, 2011 | Washing Machines
F02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore Elite HE3 model 44832 200 washer. Will spin sometimes, but doesn't seem to get to full speed. Often won't spin at all and gets F02 error, but it does roll during wash/rinse cycles. ...
he F02 message is a long drain error and it may mean the pump is clogged or bad. You don't provide a lot of detail about if the water is draining out or not but the first thing to check for this error is the drain pump.
The image below shows how to access the pump and remove the filter. This may be your only problem. With the access panel removed you can also make sure the pump is running. Remember to unplug the washer before removing the access panel.
Check the pump for the F02 and make sure you're using HE detergent and there's not excessive suds.
Jan 20, 2011 | Kenmore Elite 45986 Front Load Washer
During the Normal washing cycle. 02 F appears. and cycle stops. Cycle hasn't finished rinse or spin.
Hi
Daniel
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Getting F02 error on Kenmore Elite HE3 washing machine............how do i fix problem?
Hi
• Check the drain hose and make sure it is not plugged or kinked.
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects.
• If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore Washing Machines
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 error message. What does this mean and what do I need to do?
Her is what f02 means for your washer.
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Her is what to look for.
Good Luck
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02/Sud error message fabric softner will not dispense
The pressure switch is sensing that there is still water in the unit,it sits at the top of machine under the top cover,it is round and usually red in color remove the hose/tube from it and blow through it to make sure it is clear,you can also remove the switch itself and lightly blow into it you will hear a couple of clicks put it back together and give it a shot..
Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 & SUDS error + no spin
The "F02" error code is a slow drain error. If you have confirmed your dry lines are clear, you may have a drain pump that is either clogged, or is not working properly. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
It doesn't take much to damage the drain pump on these washers. If something is lodged in the pump for extended periods it could potentially damage the pump impeller or pump motor. The pump may SOUND like it is working, but it may not be pumping. If a good cleaning doesn't work, you may have to replace the drain pump. Replacements are available at searspartsdirect.com.
The "SUDS" error may be caused by a drain pump this is not working properly as well. If the pump gets air inside, it will begin to cavitate and can cause the "SUD" error to appear. Just to be sure, you can refer to this link as well:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
If your washer is not draining properly, it will not spin, either. I think your spin problem may be directly associated to a drainage issue. Begin with a an inspection and cleaning (if required) of the drain pump. I suspect this may be the cause of all your symptoms.
I hope you find this information helpful. Please post back with any questions or comments you may have.
Sep 03, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
447 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
