Need help with belt and pulley questions
To change the belt you need to remove the pump attatched to the motor. the pump is held on by either spring clamps or in older models, torx (star) screws. I believe the size for the torx screws is #20. slip the belt over the motor pulley and around the tension pulley and finally around the transmission. reinstall the pump and you're good to go.
What exactly do you want to know ?
I HAVE A TOP LOADING KENMORE WASHER AND IT APPEARS THAT THE WASHING MECHANISM THAT TURNS THE CLOTHES OVER TO EFFECT WASHING IS NOT ROTATING. IS THIS A BELT REPALCEMENT ISSUE OR SOMETHING MORE?
