There is no reset button it as a Thermal Cut Off
This vacuum cleaner has a special thermostat that protects the cleaner in case of motor overheating. If the cleaner suddenly
shuts off, turn the switch off and unplug the cleaner.
Check the cleaner for a possible source of overheating such as a blocked hose or clogged filters. If these conditions are found, fix
them and wait at least 30 minutes before attempting to use the cleaner. After the 30-minute period, plug the cleaner back in and
turn on the switch. If the cleaner still does not run, then call 1-800-282-2886 for customer assistance
this link below is the manual
http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
I turn off the vacuum cleaner and wait.
