I have a single feed switch/outlet that had to be replaced. The old device had 2 screws on one side and 1 on the other. The new switch/outlet has 3 on one side and 2 other. I have 2 black common wires and 2 white. When power turned back on the outlet works and the switch doesn't. Can you help?Glenn
Hi there, first what is your porous for the device? Do you want the switch to feed the outlet or do you want the switch to be independent? (switch feed outlet)---- black feed to gold screw on switch. then from lower screw on same side to outlet (this should be black also)> remembering to tie neutrals with wire nut in rear with pig tale to switch. hope this helps.
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
