Good evening. I'm trying to fix my old (2005) Samsung tv 46inches. Doesn't power up, relay clicking over and over. Removed all connectors from Power Supply board but for AC 220volts plug, it doesn't click. When I reconnect 1 plug of the mainboard it starts clicking again. I've seen no bulged capacitors on the Power Supply board, possible damaged mainboard? Should I go for a new mainboard? Thank you for reading this mail, any help will be appreciated.
SOURCE: power up problem
i will need the model number of your set in order to help you with your problem. Please post the model number and I will try to help you out with the problem.
SOURCE: power supply is bad on philips plasma 50 inch tv, it just clicks
nice job... thats the most common problem with all LCD tv's now
SOURCE: Does anyone know which connector to plug into on power supply
Double check all the connections from the AC line and from the power supply to the other circuit boards. The connectors you are mentioning are identical as per the picture below.
If you need a new power supply, you can find one from this link.
Testimonial: "I have a few more questions that I would love to ask Jaime867. He produced a drawing of my circuit board within minutes and was a big help. Thanks"
SOURCE: Lightning strike nearby caused momentary power
Main AC fuse is encased in the black shrink tubing, labeled with Fx next to two pin white AC input terminal; http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj1av4u20c17400.jpg
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Sanyo+DP42848+&stock=all&limit=100
SOURCE: Samsung LN46A550 LCD power on/off
Apparently this is a known problem with flat panel TVs made a few years ago due to bad capacitors in the power supply. This same problem appeared in computer mother boards at about the same time so that the capacitors went open or shorted causing problems.There is videos on You Tube that addresses this problem see: http://www.youtube.com/watch?v=ZccykxrtX9g as a starting point and look around for other repairs
