I have a Maytag oven. There is a glass front on the outside of the door, however over time the inside of this has gotten a little dirty (from greasy water drips, condensation, etc.) It looks as if this glass can be removed by removing the frame from the bottom. Any suggestions?
I have a Kenmore oven and all I had to do was remove the screw at each end of the handle (accessed with the door open) and the very front section just opened up - SIMPLE!! Wiped it down put the screws back in. Did it all by myself - just have your cleaning cloth in reach before you start. Can't believe I looked at those drips for years and it was that simple!!!
SOURCE: Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
SOURCE: How do clean behind the glass on Maytag built-in oven.
You should have a 2 piece glass in your oven. What has happened is that the seal that separates the 2 pieces has come apart or is broken thus allowing air and grease in. You can take apart the glass but it will only be temporary for about 2-3 months and will get dirty again. The bad thing about it is that te more you take it apart, the more the band that separates the 2 pieces becomes out of its form, the harder to put it back together. Unless you don't mind it, I would leave it alone or just replace it and be done with it. The question I have is, is the glass cracked or has the door been bent? Normally, the glass lasts for nearly the life of the oven.
SOURCE: St George Oven Door - Glass Broken
http://www.sga.com.au/User-Manuals/default.aspx
Anyway that will get you to the right people.
SOURCE: How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
Below are instructions on how to take your oven door apart to
remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit
driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off
hinges.
C. Lay door on table, position so that handle hangs freely over
edge of table
D. Remove 2 screws and washers that secure handle to lining
assembly.
E. Remove 8 screws that attach textured steel door wrapper trim
to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of
lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps
attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass
just lays onto the wool shield and is held in place by the glass/ clamps in
item
H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this
time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
