SOURCE: My daughters LG Xenon cell
battery short circuited change the battery and see that you do not charge overtime. second is recharge only after the battery has compltely been used from previous charging
SOURCE: My motorola i290 won't turn on no matter what!
I FINALLY GO IT!!!!!!!!!!!!....take the battery out 4 a few secz n pop it back
SOURCE: my samsung gt 15500 won't
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
SOURCE: HTC Hero won't charge. I
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
