Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
Anonymous Posted on Sep 25, 2017
Kenmore Oven Specific question: can I disable oven portion so that I can use the range burners without having to hear the annoying beep caused by F1 error code. I know that I will have to replace the electronic oven control board, but I just want to use the burners for now. I took apart rear oven panel; if I remove off white color modular p5 plug, would that do it? Thanks
5 Related Answers
Powerman
Charlie Popeck
  • 68 Answers
  • Posted on Apr 17, 2007
SOURCE: Ovens
The F1 error message usually means a short somewhere in the touch panel keyboard. There has been a rash of problems with keyboards. Most of the time there is a simple fix that can be used. Please see my post of April 14, 2007 in response to the problem posted by OVENMAN on April 12, 2007. There you will find a suggested solution which has helped hundreds of folks who have had error messages with GE and Kenmore ovens. If this fix doesn't work, you will need a replacement touch panel. There is no practical way to repair the keyboard in ovens.
Powerman
Charlie Popeck
  • 68 Answers
  • Posted on May 19, 2007
SOURCE: Kenmore Gas oven is giving F8 error code
Unfortunately the F8 usually means an EEPROM data shift error. Try turning the power on and off several times. If error continues, you have no choice but to replace the ERC. Check on line for the best price. There is a group in the Chicago area that repairs ERCs. Check them out at www.cgiltd.com The failure of the your power system may have been associated with a surge either as the power went off or when it came back on. It may have been the surge that did the damage.
Anonymous
  • 8197 Answers
  • Posted on Dec 18, 2008
SOURCE: my kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Anonymous
  • 6784 Answers
  • Posted on Apr 16, 2009
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Anonymous
  • 30 Answers
  • Posted on Nov 08, 2009
SOURCE: kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
3helpful
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 • Ovens
After a power outage / low current power problem this evening, my whirlpool range, Model # SF315PEKW0 started beeping annoyingly, and displayed the following code F1 E1. Also, after, the oven would not...
The "F1-E1" fault code signifies an EEPROM checksum failure within the electronic oven control. Disconnect power to the range for longer than 30 seconds. Re-apply power and observe the display for longer than a minute. If the failure remains, disconnect power and replace the electronic oven control board.
Jul 24, 2011 • Ovens
1helpful
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Thanks
My oven has been beeping for the last couple of hours. My son pushed bake and put the temp up to 425. After it preheated, it started beeping and F1 is showing on the display. I have tried everything to...
you can first try to reset the curcuit breaker
flip on and off
if this does not help
usually an f1 error is your control board
what is your full model number from inside the oven?
1helpful
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
3helpful
2answers
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
3answers
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
1helpful
F1 fault code on Jenn-Air jwg 8130
hi,
The F1 ErrorOn a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
Disconnect the power
Gain access to the back of the ERC
Disconnect the ribbon cable that connects the ERC to the touchpad
Check nothing will short when power is reconnected
reconnect the power and switch on
Watch for F1 and listen for the beep
If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
or follow the link for more info:
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-ranges.html#Admiral
thanks for your question.
6helpful
My kenmore oven is beeping and will not stop. the display shows F-1.
Dec 16, 2008 • Ovens
3helpful
4answers
My kenmore electronic stove is having a beep with code F1 on the
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
