Midland LXT303-A 2-Way Radio Logo
Posted on Mar 21, 2009
We lost our instructions for the xtra talk walkie talkies. We can't figure out how to use them! Frustrating for 8 year olds, and forty year olds alike. [email protected]
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Mar 27, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
10944
Points
30
Want to know how to make old nextell / boost Mobil phone walkey talkey or chirrup work for free
Yes it is free, You should have a walkie-talkie ID number. Friends of your walkie talkie also have ID numbers install number to Your contacts scroll down on contact to (Options)D C. From there follow directions try to make a walkie talkie contact by pressing the side (PTT) or push to talk button , It a cinch. This may only work 4 sprint
Jan 22, 2013 • Cell Phones
I lost my manuall for my GXT walkie talkie
Look online for the manual, I found my refrigerator manual online,
11helpful
I've lost the instructions for changing the channel on the our Hello Kitty KT2022 walkie talkie. It would seem simple (obviously someone played around with it and figured it out) but we can't seem...
To change the channel on the Hello Kitty KT2022 Walkie-Talkie:
-Tap the power button. The channel will blink.
-Use up/down arrows.
-Tap the power button again to save the channel selection.
The entire manual can be downloaded from here:
http://www.spectraintl.com/images/stories/pdf/hk/KT2022%20Manual.pdf
3helpful
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
19helpful
Have Cobra Micro Talk Walkie Talkies and have lost the instruction manual and do not remember how to program them
This was extremely difficult to find but I have located the manual for you on these walkie talkies. It will be easiest to just use the manual and follow the instructions. If you still have questions or problems please respond here and I will get back to you. Please rate my answer 4 thumbs up here on the site, it is very important to me. I would be forever grateful. Here is the manual:
http://www.cobra.com/downloads/manuals/PR4000WX_manual.pdf
Is kenwood walkie talkie and motorola walkie talkie on the same frequence
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
6helpful
Oregon scientific walkie talkies
Hi Neil
You can obtain the Owner's Manual (Contains simple instructions) from link below
http://www.expressfix.net/manuals/2WayRadios/OregonScientificTP329
1helpful
2answers
Walky talky
A walkie talky as we called them, back when we were younger - and hell we probably still do in some respects, hence the fact my friend still refers to her cordless phone as a "walkie talky" and the principals haven't changed that much.
The common old Walkie Talky or CB radio use what we call a half duplex, that means only one person can talk at a time. We are talking and listening on the same channel.
Cell phones are full duplex, meaning two way conversation, and this is simply listening on one channel whilst talking on another, so the basic principal is basically the same, just a little more sophisticated.
Walkie-talkie typically has one channel
CB radio has 40 channels.
Cell phone
can communicate on 1,664 channels or more!
I have included a link to a circuit diagram.
http://www.freeinfosociety.com/electronics/schemview.php?id=1870
There is also two links below, building the transmitter & receiver.
Transmitter: http://www.zen22142.zen.co.uk/Circuits/rf/2bjttx.htm
Receiver: http://www.electronics-tutorials.com/receivers/regen-radio-receiver.htm
Trust this helps, and please take the time to rate the answer given, thank you.
Top Midland Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
