My pedal unexpectedly stops working and won't allow me to turn the motor and sometimes it will only let me turn it clockwise. This problem is very irritating because all of sudden it starts to work again. Any help would be appreciated. Coincidentally my friend has the same model and does the same thing.
SOURCE: minn-kota 865 autopilot
Hello dtspins2. Your footswitch is stuck. Disconnect the DC. Remove the bottom of the foot control, check the wiring for insulation broken off and wires shorting out, and disconnect a wire(note color of wires) from switch, reconnect power to confirm motor don't run. Remove the switch and contact your local electrical supply store(may cost less) or marine store for replacement. Good Luck.
SOURCE: Where can I get installation manuel for Minn Kota bow mount maxx?
Hi there
if you go to the web site of the manufacture they havre a printable version of the manual there is even a phone number to call for help please try this ok and let me know how this works for you
best regards mike
SOURCE: Where can i get a circuit board for my minn kota
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
