As the piston moves down towards the sump, air is vented through a baffle arrangement called the breather.Sometimes a tube connects the breather to the carburettor so that droplets of oil are fumes are sucked back into the engine to be burnt. If you turn a mower on its side and the breather is on the lower side, oil can run out of the breather and possibly into the carburettor.
The carburettor is probably flooded and contaminated with oil. This should eventually dissipate as gas dilutes the oil, but try removing the filter and checkout whether a lot of oil has accumulated. Another scenario is that the air filter has become saturated with oil. If the filter is a foam type, the excess oil can be squeezed out. However if a paper filter is fitted, the likelihood is that it will have been destroyed and need to be replaced.
SOURCE: how do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: How to remove deck on 1045 cub cadet to remove and
You should be able to remove the blades without removing the deck
They bolt on from underneath with either a single or double bolt set up
90% + are single bolt
SOURCE: I cannot remove the blade as the nut just spins. I
Block the blade with a piece of wood so it doesn't turn when you loosen the nut/bolt
