hi Robert , can you confirm the following ,
is this your scooter ?
http://evrider.com/product/minirider-lite/
now , because it showing two types of flash code, sounds like a Curtis 1212 controller now the flash code means
2,3 MAIN FAULT main contactor fault 1. Main contactor welded or stuck open. 2. Main contactor driver fault
sound serious, well it can be a controller fault ,, it simply means the circuit that drives the relay has become faulty .
I can repair them cheaply...if UK based ..
did you mean ?
3,2 BRAKE ON FAULT brake On fault 1. Electromagnetic brake driver shorted. 2. Electromagnetic brake coil open.
so what does that mean well ?
most likely the connection between the read axle and the frame so check them out , making sure they are a good connection, maybe use some contract spray, if the axle is not removed often then I suggest removing the axle and try refitting it may well sort the issue .
regards
Rob
www.gewizrepairs.co.uk
