This what you do. Connect the video wire to a power suppy and install a switch in the power wire. When you put the DVD in and the warning comes up, turn the switch on then off. This will allow you to watch the DVD without the park brake being applied.
Just use an ordinary Automotive relay in place of the switch and hide the wiring under your dash. When you want to watch a movie just pop it in press the continue button on the screen and bobs your uncle, no switch to flip on and off, no p/b to set, no jerry riging of wiring to get it to play....no fuss no muss!!!!
On the P4000dvd its actually a ground not a power. The green lead which is labelled for the parking break goes to a switched ground. Each time you want to use the video options you must activate the switch (i find push button ones work the best)
