I need instructions on how to set the clock time, date, etc.
SOURCE: ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
SOURCE: Need instructions for a ULTRONIC WORLD TIME CALENDAR,
How to set the ULTRONIC WORLD TIME CALENDAR 01-22-2011
1. press the SET (MRC) key. The SECONDS in the lower right corner will start to blink
2. press again and the HOUR will start to blink. And again for the MINUTES, again for the YEAR, again for the MONTH, and again for the DAY DATE.
3. when you get the number you want to set, press the UP (M-) or DOWN (M+) ARROW key to adjust that number as you wish.
4. then press TIME to lock in that number.
5. repeat as needed to set the other numbers
SOURCE: setting an ultronic clock
Press "Mode" once to view the calendar
Press Mode again to view the alarm time
Set Time:
Press and hold Mode for 3 sec. to enter the time setting...Hour blinks..change by using Up or Down buttons. Press Mode again to set Minutes Press Mode to finish
Set Calendar:
Press Mode to see calendar
Press Mode for 3 sec to set year. Year appears, blinks...change with up or down buttons
Press Mode ..month appears...blinks. Change with up & down buttons. Repeat for day. Press Mode to finish
I have a ultronic TDoo552 clock that I cannot set. HELP
