Need to buy a gfi or relay switch for my tankless water heater, noritz n-069m... any one know where or what site?
SOURCE: Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
SOURCE: Water Heater Won't Fire up
does the fan come on? this has to happen before it will even try to start if it doesn't your problem goes farther into the unit,, normal pracess if the fan then the ignitor then the flame, It could be in the circuit board most people that have gone with the tankless don't clearly ask the question but that is normal, but if you could clearify the procedure of what it is doing to this point i could be more helpful to you---- e-mail me what is happeing diffrent then what it use to do [email protected]
SOURCE: what is error code 59 on a noritz tankless water
The 59 code is typically caused by insufficient gas supply to the unit. It can also be caused by obstructed exhaust flow, stuck exhaust damper (located directly on top of the unit's exhaust), insufficient makeup air, or improperly installed venting (i.e. too long or too many elbows).
I would recommend initially checking the incoming gas pressure at the gas connection on the unit. The gas pressure should not drop below 5" water column for a natural gas unit, 8" for a propane system (the unit need to be operating at its maximum output).
There are a few things you'll want to check:
1) make sure you have 120VAC at the outlet
2) measure voltage across the blue/white and black/white wires connected to the gfi (black box inside the unit on the bottom left or right hand side). You should read roughly 100 VAC on both sides. If you don't read voltage on the black/white wire pair, then you gfi is tripped. Look for moisture that might be shorting the gfi.
3) If the GFI checks out ok, you probably have debris clogging your flow sensor
SOURCE: error code 14 shows on the remote for a noritz
This means the thermal fuse has broken and needs replacement. The thermal fuse is a white cord which wraps around the heat exchanger. It typically breaks if the unit is excessively dirty and sooted. Before the fuse is replaced you should make sure the unit is cleaned with compressed air and descaled.
