Dell Latitude C640 Notebook Logo
Anonymous Posted on Aug 17, 2007
Dell C640 wireless not working
Just bought a second hand dell C640 with windows installed and the wireless card would appear. Formated the hard drive and reinstalled windows now there is nothing about wireless showing. looked for drivers on dell.com but only found drivers for external cards.
  • 1 more comment
  • Billymc71 Dec 28, 2007
    my Dell latitude c640 had windows 2000 pro i added windows xp home and it wont even read the wireless card i have tested it with. wireless is impossible to access. I put it in and it shows its a ethernet card or adapter however it will not even install the drivers and says there was a problem. i am useing a Dlink airplus Xtreme G 2.4ghz wirless netbus card adapter.
    Thankyou
    Mr. billy Mc
  • Anonymous Mar 27, 2008
    the same problem........i'm working on it
  • dagdogdude Feb 22, 2009
    I reinstalled XP but now there is no wireless card showing in the network connections....
Getta Biggerhammer
Level 1:
  • Contributor 5 Answers
  • Posted on Dec 06, 2008
Getta Biggerhammer
Contributor
Level 1:
Answers
5
Questions
0
Helped
58346
Points
23
I used Everest home edition to find the wireless drivers for my DELL C640 laptop.   The wireless card in it is an  ntel PRO/Wireless LAN 2100 3B MiniPCI Adapter (IBM). I've downloaded the wireless driver from Intel's website, here:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=944&OSFullName=Windows*+XP+Professional〈=eng&strOSs=44&submit=Go!#DRI
It's the 3rd result in that search page. If the link doesn't work, simply search for Intel® PRO/Wireless 2100 Network Connection on Intel's site.
That Dell C640 wireless driver works fine for me, I'm using the wireless card to type this :)
good luck!
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6437
Points
Wireless is built in. Without driver installed the model does not show, so knowing what driver to use by model number is not option. Dell support now uses download app which must sit on machine, with Inet connect, but no connect without wireless working.
How do you solve this?
OMR
Fred Steinberg
Level 1:
  • Contributor 65 Answers
  • Posted on Aug 17, 2007
Fred Steinberg
Contributor
Level 1:
Answers
65
Questions
0
Helped
60882
Points
79
Pop out the wireless card and look for the model number. It's probably an Intel card. Go on the site of the manufacturer and download the driver.
electronic & computer repair& servicre
Level 3:
  • Dell Master 12,061 Answers
Dell Master
Level 3:
Answers
12061
Questions
0
Helped
4005255
Points
36390
Get Aidia32 this program will identify your hardware and that way you can get the right driver. www.sofotex.com/AIDA32-download_L9326.html I think these are the drivers ya need? http://www.station-drivers.com/page/atheros.htm
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 31, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
6055
Points
I Recomend getting Driver Robot 2.5 Build 3.0 Software,,i tried everywhere to fix my c640 problems with the wireless network and my friend who is ace on comps couldnt even get it,,however after installing driver robot it was fixed in ten mins and running great,,not even the Dell site could give me anything to work this little machine,but its now going great guns,,hope this helps folks,,
My sd ms pro..in build port.. is not working.... recently i formated my laptop..
Access http://support.dell.com and find your model.
Look for the device-driver for the multimedia memory-card reader.
Install it.
1helpful
I HAVE A DELL C540/C640 MODEL PP01L I WANT TO KNOW THAT IN THIS MODEL CAN I ACCESS WIFI OR NOT?
If you model has the optional wireless card installed.
To check, click Start - Control Panel - System - Hardware - Device Manager - expand Network Adapters and if the wireless card is not listed then you don't have a wireless card.
If there is a wireless card and it has a yellow ? against it then the wireless card driver was not installed. In this case -
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
2answers
Wireless problem 4 ma dell c640 laptop
Hi. first is to verify whether you have a wireless card or not by going to the device manager from the control panel.
Expand the network adapter and check if your system came with a WLAN or wireless card. If it's a Dell True Mobile wireless card, you can download the latest driver from this link:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R69905&SystemID=LAT_PNT_P4N_C640&servicetag=&os=WW1&osl=en&deviceid=2491&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=0&libid=5&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=90951
then try connecting to your router by right-clicking the network icon from the taskbar (lower right-hand corner of your screen) then select view available networks and if you see your network there, click it and then connect.
^_^
I am going to install a wireless card in my Dell Latitude C640 laptop. I recently watched an installation video on youtube. I noticed there was some sort of wireless antenne mentioned. Are they...
i dont think the c640 usually comes with wireless so i dont think the antenna will be in there so you might have to get them. but you can take off the ram cover on the bottom and see if the wires are there. this shows the wireless card in there
http://support.dell.com/support/edocs/systems/latc640/sm_en/upgrades.htm#999869
Using Pro/Wireless 2200BG with Latitude C640?
OK generally if you have the drivers and it fits in the slot than there is NO reason why it would not work. As for software, one goes to the manufacturers web site and download relevant drivers, & install.
One of my Dell Latitude C640 laptops cannot find or connect to the wireless network. My other one will. They do have two different wireless cards, but I've compared all settings & they seem to be the...
card is hardwere. you should instell softtwere.softwere make any device active. you can get wireless softwere,in your board cd. install it .it can work
No 3d acceleration in Vista on ATI 7500
Well, I'm amazed a C640 runs Vista at all. There's no reason to buy a new hard drive, except for the novenlty of having one loaded with Vista on a C640. It's a great laptop, and runs Windows XP PRo perfectly well. If you have one od the Dell XP install disks, just boot from it, and whenever it finds the vista install, hit excape, then at the next screen hit "D" to delete the partition, then choose "quick format", and load the Operation system. If you need an install disk,let me know. Good luck
After installing the modem it doesn't work
YOur PC do not detect the modem... try to ensure all connection is proper
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
