Refrigerators Logo
Anonymous Posted on May 31, 2013
Ice Maker not working
Makes one set of cubes,fills back up with water they freeze but never come out again
Archie Ferrarini
Level 3:
  • Master 869 Answers
  • Posted on Jun 01, 2013
Archie Ferrarini
Master
Level 3:
Answers
869
Questions
9
Helped
335384
Points
1789
Replace the icemaker
5 Related Answers
Anonymous
  • 237 Answers
  • Posted on Dec 11, 2006
SOURCE: The water continues to drip after the ice cube maker is full.
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle. http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JCD2295HES&mfgModelNum=JCD2295HES&fkMfgID=1
Anonymous
  • 473 Answers
  • Posted on Oct 18, 2007
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Anonymous
  • 4 Answers
  • Posted on Mar 21, 2009
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
jonniewalker
Starnley Johnwells
  • 1031 Answers
  • Posted on Mar 29, 2009
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Anonymous
  • 142 Answers
  • Posted on Jun 02, 2009
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
1helpful
The ice maker line freezes. I have thawed it, gotten water flow and one set of cubes but the line freezes again before in the time it takes to freeze the first set of cubes. What should I check next?
Check the water pressure or any filters in the water line or a crimp in the supply tube. Also make sure you totally defrost where the water enters the ice maker.
1helpful
U line water comes in shuts off the fills again before freezeing cubes
the thermostat is what determines when the ice maker should start a harvest, could also be a bad valve
2answers
Ice Maker WR30X0327 Freezing Over I have an
We have extremely hard water in the East Mountains of NM. Our refrigerator Ice Makers only lasted about a year before the Calcium from the underground Calcium just killed them. I solved the problem by buying, from ebay, a small restaurant ice-maker. I Always fill it with filtered water, and it has been chugging away for years. Our water tested Harder than an Hot-tub maker had ever seen, even after going through our old, Sears, water-filter. Ergo - how hard is your water? Could that be the problem. Just a thought.
1helpful
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
2helpful
Ice maker doesn't work
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the water inlet valve ( the piece that the wall water line connects to on the fridge ) . Also check to be sure that the fill tube from the back of the freezer to the ice maker , isn't blocked with ice , as this is caused by a seeping bad water valve . If the ice maker doesn't dump the cubes , after freezing , then replace the ice maker . Also check to make sure the coils under the front of the refrig , are clean of dust , lint , pet hair , etc.
2helpful
4helpful
3answers
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
