Question about Elna Sewing Machines
Elna Carina won't zigzag
The arm wants to stay to the right but does go to center for straight stitch. I you move it to left, it goes to the right on the first stitch but won't return left. It hasn't been used for a long time.
    Novelist:
    Habit-Forming:
  • Elna Expert
  • 116 Answers
The machine's needle arm is not swinging left and right correctly, do I understand your problem correctly? I assume that you have the stitch selector set to zig zag, stitch length dial to 2 (green zone on the dial) and stitch width set to 4 to select a zig zag stitch. Needle up, push the needle bar to the right of the machine. Push above the needle thumb screw, dont push onto the needle itself. Pull the bar to the right, then release. It should return smoothly to the middle position. If you set the width to four and push the needle bar to the right, there is a spring that returns it to the middle, if this is not happening then good chance the needle bar cradle is seized up and the spring cant move it. You will need to take off the top of the machine and get some oil down the needle bar into the bearings, then apply pressure to the side of the needle bar, push to the right side to free up the bar movement. triflow oil is best and a means to deliver a drop or two down deep inside. I dabbed oil onto the needle bar with cotton swap stick on my machine that had this problem. You should be able to see a horizontal metal tube down there above the needle, the needle bar slides back and forwards on this but machines left can seize up due to dust, and dry old oil forming gunk on the moving parts. you need to lubricate and get it sliding freely again, you should be able to free it up with a bit of time, oil and gentle movement. mine took a couple of days to get it moving freely fully, it would give it a wiggle, dab of triflow oil, leave it, then have another go. I got triflow from a bicycle eshop on ebay, great stuff. Hope this helps you with your Carina, if not, post again and I'll try to help
Posted on May 31, 2013
6ya staff
SOURCE:
Anonymous
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
bargainbox
Hassy
  • 1388 Answers
SOURCE: Zigzag stitch not right.
This is an issue entirely related to the timing of the hook to the needle.
What model is your machine, top loading or front loading bobbin ?
The correct passage of the hook behind the needle, is generally very similar for either type of bobbin...adjustment requires the ability to disengage the shaft movement tying the top (needle) and bottom (hook) so that each may move separately and the small adjustment be made.
As the needle rises from the lowest position approx 1.2mm, the tip of the hook should be at the point of beginning to pass behind the needle, to pick up the bobbin thread, when in wide zig zag and at the widest and furthest travel of the hook........there is a shallow "groove" in the back of the needle just above the eye to allow a very close pass by the hook as it whizzes around.
If the hook travels clockwise, the furthest needle position is when the ZZ is in the right stitch position, so conversely, if the motion is anti-clockwise, the left needle position is the one to set.
The method of releasing the two shafts from each other will depend on the machine model, typically there are grub screws on the bottom shaft near the drive belt, or connected to the handwheel at the top........generally 2 screws at 60 degree offset in either case.
Re-timing is not especially difficult, but does require knowledge of the screws to aim for, hence the model is necessary info.....
...If you want any more help with this, just post back here with a photo of the machine (< 150kb) , or, drop a line through the "Contact Us" page at www.bargainbox.com.au and remind me of the posting.
Posted on Jun 01, 2008
Anonymous
SOURCE: singer 2662 only does a straight stitch
got the same problem - wish I could help you -
Posted on Jan 13, 2010
paj42
  • 1116 Answers
SOURCE: i have an automatic supernova circa 1955. I often
When was the machine last serviced by a sewing machine tech? It could be old lubricant and dust have gummed up the gears.
Carefully warm the area with a hair dryer to see if this will loosen up the selector.
If the problem continues, the machine will need to go into the shop.
Expect the bench charge to start at about $80 just to do a routine cleaning and lubricating.
Posted on Mar 18, 2010
SOURCE: Viking 1+ Horizontal movement quit working after needle hit something
it sounds like you knocked the machine out of time & it will have to be taken to a
sewing machine shop to be retimed
Posted on Apr 27, 2012
Did Elna Carina SU 66 originally come with a straight stitch foot and throat plate?
No, the Carina came with a standard zig zag plate and 5 feet I think from memory, the teflon coated foot , the embroidery foot, buttonhole foot, zipper foot and darning foot.
Nov 16, 2016 | Elna Sewing Machines
Elna 3007 reinforces every stitch.
It is in Stretch Stich mode....(SS)
Check your manual to reset in normal mode
Apr 07, 2014 | Elna Sewing Machines
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
My elna has cams to upgrade the number of stitches it can do but I am unable to get them to work. I believe I have installed them correctly but cannot activate them.
Throughout the Swiss Elna range there were several of their top of line models that have the black cams for additional stitches and they all have an "Elnagraph" device in the top of the machine case where you insert the cams.
There are single cams where the needle just moves ffrom side to side while the fabric moves forward. And double cams where the needle moves from side to side while the feed dogs move the fabric forward and backwards to get a combination stitch. The trick is to get the Elnagraph to engage so the arm in it can "read" off the disc.
There are a couple of other knobs that you need to adjust to get the cam stitch though.
Star Series: (white machine with blue top) you need to put the stitch selector inside the elnagraph flap to "A" on the Star series and then stitch width to 4 and stitch length to the red A zone.
Air Electronic SU or Carina: you have 3 knobs from left to right - stitch selector (put it on 7) , stitch width (put it on 4, orange area) and stitch length (turn it around to the orange zone for the automatic stitches).
And on the early Supermatic the adjustments are a little different again.
And ALWAYS turn the stitch width and length dials back to zero, before you change the stitch selector, or pop out a cam.
I hope this helps you get your Elna stitching from the cam, there is a great Yahoo group called Elna Heirlooms too where there are lots of knowledgeable Elna owners and some files listing all the cam stitches.
Apr 10, 2011 | Elna Sewing Machines
Which food sood i use to make an invisible hem
blind hem foot is good if you want to machine stitch a hem but not have a seam showing. it will have an adjustable piece you can move left or right with a screw. but blind hemming works best on straight grain and not on a curve like a skirt hem unless its a knit fabric that gives. to make a blind hem press the hem allowance up then turn the main garment piece back to form a Z shape. you then stitch along the hem side with your blind hem foot guidr running along the top fold and use the blind hem stitch which looks like three little zigzags then one big zig far to the left onto your folded piece taking a little 'bite' - this stitch shows on the right side when you press the top of the Z back flat. so you need to adjust the foot position and how wide the needle swings to minimise this stitch showing. hope this makes sense and helps you with your sewing.
Dec 19, 2010 | Elna 2007 Mechanical Sewing Machine
Needle position
First, select straight stitch on your pattern selector. Check your zigzag setting to see that it is on zero.If this doesn't help, push the needle bar to the left and see if it will move. It's possible the assembly is seized and won't move the way it is supposed to.
Next, try the widest zigzag stitch. If you only get a straight stitch it is time for a service.
sewman7
Jun 08, 2008 | Husqvarna Lily 540 and 550
Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Jan 31, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
569 people viewed this question
Top Elna Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
Douglas Plant
Douglas Plant
Elation Relation
Level 1 Expert
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
