Obtain or purchase Battery Checker. $10 or less. Then test the batteries. If charged, disregard red light and pull batteries from charger and disconnect charger.
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
ā¢With the Charger Plugged In ______________________________________________________________________ ā¢Headset Indicator Headset Status Red-----------------------------------------------Charging (battery level less than 50% charge) Yellow-------------------------------------------Charging (battery level more than 50% charge) Green--------------------------------------------Charging complete
---------------------------------------------------------------------- ====================================================================== ====================================================================== ====================================================================== ---------------------------------------------------------------------- With No Charger Plugged In __________________________
Headset Indicator Headset Status ______________________________________________________________________ Off ---------------------------------------------Power off Three blue flashes------------------------Powering on/off Steady blue --------------------------------Pairing/connect mode Rapid blue/purple flashes -------------Connection successful Quick blue flash --------------------------Incoming/outgoing call Slow blue pulse --------------------------Connected (on a call) Slow blue flash ---------------------------Standby (not on a call) Slow red flash ----------------------------Idle (not connected to phone) Slow purple pulse -----------------------Connected call muted Steady red ---------------------------------Attempting to connect Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on ----------------------------------------------------------------------
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Just from what you say I would try to use the Laptop without the battery. If the system works, I would suggest a new battery. It is possible that the charging circuit has failed but the only way to prove this is to fit a different battery. If the computer shuts off when unplugged then the battery is not charging. They only last about 2 years depending on how much it is used. Hope this helps.
0) Obviously, helicopter will operate best when fully charged... if
charging light gets brighter when unplugged from helicopter, then it's
not at full charge. Charge fully, then allow battery to cool for 10
minutes. Good batteries in remote also. 1) Power on helicopter. 2)
Place on level surface and let gyroscopes sync. There is a red light
inside the body (NOT the red/blue flasher in the nose) that will blink
when you turn helicopter on, and will keep blinking until craft is level
and stable for a few seconds, then will stop blinking. 3) Make sure left joystick is all the way down. 4) Power on remote. 5) Throttle up (left joystick) until blades move and then all the way back down. This should get you flying. Let me know r
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Will you don't say what chair you have and they can all be wired differently. Look under the shroud that covers your batteries and see if there isn't a wiring diagram there. If you let me know the brand ie: Pride Jazzy, Invacare M51 etc. I can give you the proper wiring for the batteries. Now you also didn't say if you charged the batteries after you installed them. Remember always charge before use. Just because they are new doesn't mean they are charged (in fact they could have sat on the shelf for a while). Make sure that they are no older than 4 months old even new batteries can be bad. Charge these puppies overnite. When you plug in the charger you should see a red and yellow light after charging overnite you should see a red and green light( indicating full charge) If when you plug the charger in you get a red and green light then something isn't wired correctly. Hope this helps
most psp chargers are fitted with a cut-out.
which means that when the batteries are fully charged.
The charger shuts off.
A full initial Charge ( New-Battery ) could take 4-8 hours et,c Dependant on Capacity.
also a red light to green, can indicate full charge.
You need a new battery! After 2 years of ownership, mine is doing the same. The battery is 'spent' - shot, kaput. They only have so many re-charges. Now to find the battery that fits....
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
