Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50" Logo
Anonymous Posted on May 30, 2013
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Cub Cadet runs well for 20 to 30 min. and then it stalls like it is running out of gas. After 20 min. cooling time, it runs fine for a period of time again. I changed the fuel filter but didn't see a change. Is there an automatic shut-down if it gets hot?
Andrew White
Level 3:
  • Cub Cadet Master 2,239 Answers
  • Posted on May 31, 2013
Andrew White
Cub Cadet Master
Level 3:
Answers
2239
Questions
Helped
908530
Points
5950
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
5 Related Answers
Tim Whalen
  • 3076 Answers
  • Posted on May 21, 2011
SOURCE: cub cadet model LT1050, when
I believe the problem is a safety feature which is connected through the RMC, like the seat switch, just do a search for RMC on this PDF Manual it will show you how to check and what does what, Hope it helps and Good Luck Tim:
http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02100.pdf
Anonymous
  • 43501 Answers
  • Posted on Jul 14, 2011
SOURCE: I have a cub cadet RZT 50 mower deck and my
The problem is the clutch it's self... it is slipping and when it gets too hot it just quits...
The clutch will need to be replaced and that often is not a fun job. You also should have specialty tools to do the job, as they are very hard to get off the shaft many times... the same heat that stops the clutch, almost welds it too the shaft...using heat to free it therefore does not work like it normally would.
Just for giggles a grins, check for power to the clutch after is stops...I think you will find that it is still getting power to it, it just is not engaging or staying engaged anymore...
heatman101
tim kinder
  • 32 Answers
  • Posted on Apr 21, 2012
SOURCE: 1641 cub cadet how to check fuel shut off solenoid
it wont start at all if the solenoid is unplugged try and see if it will run with the choke about half way on if so you have trash in your carb
philwalker78
Phil Walker
  • 610 Answers
  • Posted on Jun 01, 2012
SOURCE: cub cadet series 2000 stops running after 20 minutes cutting
Hi, check that you have spark. they are renouned for doing ignition modules in. Regards Phil.
Anonymous
  • 32 Answers
  • Posted on Aug 11, 2012
SOURCE: Cub Cadet 1050 runs and shuts off after mowing for a bit new fuel line and filter cleaned carb and tank and gas cap is vented am i missing something? I'm losing my mind trying to figure it out
coil
2008 cub cadet rzt 50 run for 20 min than dies while mowing put new pump on, new fuel filter, new air cleaner, new plugs. has a 22hp kawasaki engine. fuel lines clear
When it stalls out did you check the spark? I suspect the engine is losing spark due to an ignition system failure.
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Tractor is dead.
charge the battery start tractor and check the voltage at battery terminals should min 12volts and rise to about 13.8volts if not charger is RS
Cub cadet dies 20 minutes after starting
Slacke off the fuel filler cap when it starts to die, if it picks up again the fuel tank breather is blocked.
Cub cadet model LT1050, when i release the brake the engine wont stay running, but starts and runs fine if i hold the brake in
2helpful
LT1550: runs for about 30 mins on 1/2 to 3/4 throttle. sputters and DIES!!!!! I have to wait a day or two before it would start again.
Try this:
When it begins to stall, loosen the gas cap. If the engine smooths out, clean the vent holes on the cap.
Gary
97 lumina, 3.1. Starts runs smooth, drive for 30
I just recently have been fighting the same problem with the same make/model/year vehicle. For myself, I would drive off and on through the day and it would run fine. Then suddenly after a start it would run rough and die. I would have to wait 20 to 60 mins before it would start again. I had it checked and fuel pump was only putting out around 19 psi. It should be around 41 psi. Had fuel pump replaced and no more problems. Furthermore, now it runs so much better. It's funny how over time I didn't notice how the performance was slowly degrading. Unfortunaley fuel pumps for this car run around $300.
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Top Cub Cadet Garden Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
