Dell Inspiron 6400 Notebook Logo
Posted on Mar 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Modem for Dial up
I have a Dell Inspiron 6400 laptop and have a program that needs a dial up modem, I went to the Computer store and bought a Zonet 56K V.92 PCMCIA Modem Card. I need to know if this is compatible and do I install it on the right side of the system?? Thank you
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Mar 21, 2009
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1404368
Points
12062
It will not be compatible, the slot on the right side is an ExpresssCard Slot.
You might want to try a USB modem
http://www.zoom.com/products/dial_up_external_usb.html
Can I download modem on dell laptop
Most of the time on laptops if there is no phone input for a modem you cannot just plug in and dial up. The process i use at home for my pc is dialing through my cell phone. If your carrier will allow you to tether your phone without extra charges check your phone manufacturers website for modem software. You then just connect your phone through a usb cable and set a internet connection matching your carriers instructions. Another solution is dificult without networking knowledge but you can set up a home pc with a wireless antennae as a ad-hoc server through internet connection sharing and then allow your laptop to connect through the "server" pc.
1helpful
2answers
Laptop won't recognize dial up modem. I'm not sure if the small internal modem is all I need for dial up access, or if I need to get a PCMIA card. It's a Dell Insprion 2650 laptop. Thanks
If the internal modem is functional and the driver is installed, then that should be all you need for a dial up connection. If the modem is listed in device manager without a Yellow Exclamation Point then the driver is likely loaded properly. if it does have an exclamation point, then you may need to load the driver. There were 3 different modem models shipped with that system.
Actiontec MD56ORD PCTEL Connexant D480
drivers are here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=INS_PNT_P4N_2650&os=WW1&osl=en&catid=&impid=
If installing drivers doesn't resolve, then a PCMCIA modem is a inexpensive option
1helpful
My sister bought a Dell Inspiron 1750 computer from QVC and there doesn't appear to be a modem loaded on this model for dial-up. Is there supposed to be?
No, the Inspiron 1750 model doesn't use internal modem to connect to the internet. It does rely on its Network Adapet (Lan port) and wireless to connect to the internet.
2answers
My fiance is the the military! I sent him my old Dell latitude CP ... I forgot that it doesn't have a phone plug to connect to the Dial up on base. Is there a way to connect to the internet I don't...
I bought my sister a Dell laptop that didn't have a dial up modem in it, never saw one that didn't have one.
Dell sells a dial up modem that goes into the usb port for about $35, which I sent to her and it works. Basically it is just an external dial up modem.
Give it a try, just call the dell help phone number.
3helpful
2answers
My new pc Dell Inspiron desktop has no modem built in for dial-up internet connection. Im currently subscribing to a dial-up service provider on another pc, how do I connect to the same dial-up service...
You have to configure Internet Connections Sharing on the PC which has a dial-up service.
1. Click Start - Settings - Control Panel - Network Connections, right click on dial-up.
2. Clik on Properties, click on Advanced tab.
3. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box
After that you must connect the other pc to this one via network cable.
If you don'y have network adapters you have to buy them.
1helpful
Do I need a modem card?
If you will be using a DIAL-UP internet for that computer, you really need a PCI dial modem for it and it will come with a setup CD that you need to run to that computer so all software will be installed for that dial up modem and that should be it....
Inspiron 6400 wirless connection
HI
If the browser shows working offline and wireless is connected fine then it could be an issue where work offline is checked in the browser.
In internet explorer 6 its found on File in the menu, if work offline is already checked, check it again to remove the check mark and then try, if its internet explorer 7 its found on tools, the same steps and in firefox under file,
Also try this step as well, if its internet explorer go to tools-internet options-and in internet options-go to connections tab-there is dial up and networking box-remove the dial up connections from the box-and check the one never dial a connection
also check the firewalls and antivirus programs, post your results.
thank you
rakesh
Modem not working
Here is the url for dell drivers:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
I don't think you would be using modem for internet connectoion.
New computer running slow
if you are using dial up, you shud not have a modem.. modem is just for DSL connection
if you have a modem probably you are using a DSL connection
DEFINITION:
dial up - connection using a phone line with internet connection; cannot use fone while on internet
DSL/modem- connection using a modem plugged in with computer and fone line; able to use fone even when on internet.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
