Urgent need of manual for AudioLogic Digital Answering Machine...
I own an AudioLogic 14 Minutes Answering Machine Model APH 7887.
Since my recent move I cannot find the instruction manual for my "AudioLogic Digital Answering System with Date/Time Stamp" which I need for reprogramming the whole thing or at least to record the voice message because I do not recall what I did the previous time.
I have Googled "AudioLogic" but the results are companies who doesn't seam to make Answering Machines.
Recent Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual Voltage Cordless Phones Integrated Answering Machine 110-220 Volts questions, problems & answers. ... Model KX-TG4021 - How do I put in a new answering message? ... Why won't my answering machine, Panasonic Easa-Phone KX-T1460 allow the ...
www.technibble.com > Forums > Other Discussions > General Chat
Dec 9, 2013 - Recovering deleted messages from a digital answering machine ..... AT&T cordless phones - I don't know how similar that would be to Uniden.
forums.verizon.com > ... > Home Phone (Landline or Digital Voice)
Mar 16, 2015 - I have to say, though, I doubt you'll be able to recover the messages. Digital answering machines typically don't have an un-delete. Good Luck.
Dec 14, 2013 - Delay needs to be at least 30 seconds because voicemail takes just over 30 ... If you don't know your four-digit pin, it's possible you haven't ...
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Background: The TAD1220 does not have a way to manually delete messages. It more or less has a FIFO(FIRST IN-FIRST OUT) method of retaining messages. It will save up to 14 minutes of messages and then they are deleted automatically after you play them back and receive another incoming call. This is important: It will only erase the messages AFTER you have listened to them *AND* received another message.
Exception: If you happen to press the STOP/SAVE button, then all of the messages will be RE-SAVED until the memory limit has been reached.
Extreme Solution: The only manual way is to remove the battery, disconnect the power cord and erase everything. You will then need to reprogram your greeting.
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
Need manual to set up my machine, Model APH7887.
