Simply turn over,and remove 4 screws holding in circular wood insert. Remove and the motor or fan is attached to it as you take out. Careful not to pull too hard as it is attached by 2 wires without a plug type connection with which to remove it. It can only be pulled out to a certain extent before the wire restricts it's movement outside the body of the organ.Most of the time, if it isn't working, you'll find debris may be restricting its movement. You will know if the power seems to be working, but no movement in the fan. It should spin.
