Question about Exercise & Fitness
Precor c965i won't maintain speed the more weight on it
The treadmill operates well with someone of 140 lbs, but 190 lbs+ it won't go past the speed of 5. If I step off, it will speed up to the speed requested, but once I step on, it starts to slow down and maintains a slow speed.
    Top Expert:
  • 12,223 Answers
Weel you must read the specification of your model, what is the maximun weight that is acceptable. However you must LUBE the deck belt with silicones or wax , read your owner manual for this, and execute inmediately.
God bless you
Posted on May 30, 2013
6ya staff
SOURCE:
Anonymous
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
Anonymous
  • 95 Answers
SOURCE: Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Posted on Aug 01, 2009
Anonymous
  • 3 Answers
SOURCE: Treadmill will not maintain the correct speed.
your belt may not be tight enough and it is slipping which can cause it to move faster than the motor
Posted on Aug 26, 2009
taran_2005
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: My Precor 9.21 si Treadmill shuts down upon
Hey Doug,
Just wondering has this unit ever had the running deck flipped over if not this may be sighs of worn deck or belt or both! What is starting to happen is that at the higher speed the unit is starting to draw more current, so the motrol control board will sense this and will shut down so it won't damage either the motor or board. What starts as an occassional shut down will progressively become more frequent. Simple test is put your hand palm down between the belt and deck,if you feel uneven ridges then the deck needs to be flipped over and when you pull out your hand out and their is a black sooty film on the back of it ,then that seals it this means that the composite material is being shaved off. Most likely the belt will have a smooth glazed feeling in the middle part of it. and well also need replacing.
Posted on Mar 14, 2010
Precor treadmill err26
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Dec 16, 2013 | Exercise & Fitness
Precore m9.43 treadmill error 22
Precor Error Code 22 Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Feb 05, 2013 | Precor 9.21 Treadmill
Model: All Models
Recommended Action:
Precor 9.45 err 26
Model: All Models
Recommended Action:
Feb 04, 2013 | Precor Exercise & Fitness
The treadmill shuts down as I go faster
This happen because the lack of LUBE maintenance schedule
Lube with 100% silicones or wax see your instr. manual
2) Lube the rollers bearing. with wd-40
3) test the drive belt motor.
4) Test the input voltage motor, if there are the motor need repair
see my personal TIPS for motor help
5) Test the output board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Dec 05, 2012 | Precor 9.31 Treadmill
Precor Treadmill 9.21si Error Code 26, what does it mean
Model: All Models
Recommended Action:
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Precor 9.35 Problem--Please Help!
Model: All Models
Recommended Action:
Jul 21, 2012 | Precor 9.35 Treadmill
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
Apr 27, 2009 | Precor C956i Treadmills with HR /...
Exercise & Fitness Logo
196 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
