Can't connect the TEch Pro EQ-B5150 equalizer to my TEAC AG-790 receiver. Tech Pro did not provide instructions with the equipment. I called TEAC' s technical support to ensure that I connected it properly and they agreed that I had.Can't connect the TEch Pro EQ-B5150 equalizer to my TEAC AG-790 receiver. Tech Pro did not provide instructions with the equipment. I called TEAC' s technical support to ensure that I connected it properly and they agreed that I had.
You can't post conmments that contain an email address.
eBayFind great deals on eBay for Technical Pro Speakers in Speakers and ... Package: (2) Rockville RSG12.4 Single 12" Three-Way, 4-Ohm Pro Audio ... Pro STAGE-212XU 3,000 watts Powered Speaker + 8 channel Mixer System + ... Technical ProPSHAKE1500 Two Way 15" Active 1500W Speaker Bluetooth and USB / SD.
Does the receiver have a model number? THAT is the center of all this and will dictate the connections. Be advised, if it is a digital multichannel receiver ONLY analog 2-channel program material wll pass through it the attached devices. If you activate the Tape Loop either external processor is on it will disable any digital sources. Such is the common limitation of having digital capability.
Generally, OUTs go to INs. If there is a PHONO input don't use it for anything but a turntable.
Manuals are better at this than having us re-invent them. Seek them out by using a common search engine to find the manufacturer's website or these guys...
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
