Is there any way to stop the Windows Generic/Text printer from resetting the printer label settings. I need it to print Direct-Thermal, however when printing via the Windows Generic driver it resets to requiring a Ribbon. Saving settings permanent on the printer does not have any effect. Thanks
SOURCE: Zebra z4mplus printer resets to thermal transfer
Please go to the inhouse program & click printer properties and
change the printer setup to direct thermal and that's it.
Joe
SOURCE: every label printed starts further down on label zebra 105se
It sounds like the problem is with the media sensor. Make sure you haven't loaded the ribbon through the same slot that the paper enters on the media guide. There is a reflective metal plate above the media that reflects the sensor from below the media.
SOURCE: my zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
SOURCE: I have Zebra tlp 2844
So you have Zebra LP2844 or TLP 2844?
try diferent driver and print test page
www.seagullscientific.com
