I have a computer I have not used for a while. I forgot the password to unlock the system. How do I get in.
If you want to know the easiest way. This all-in-one password recovery software will surely help you out. It is capable of resetting forgotten or lost Windows Administrator login password, and recovering lost password for multiple web browsers, mail clients, FTP clients, chat messengers etc. Regards.
As soon as machine leaves BIOS screen and goes black, press F8 a few times until you see the Windows boot menu and choose "safe mode".
The machine will either then go to the welcome screen or some other sort of login...
Choose "Administrator" (or type in administrator for the username if so prompted" and do not type in a password.
Press OK (or press <enter>) and pray there is no password on the administrator account.
If you get in, open the control panel and then open user settings, choose "your" login and change the password to whatever you like.
Reboot, and login as normal.
There is probably a little jumper on the motherboard that says either CMOS or PASSWD or CMPASS. Put this jumper in the position opposite from what it is now and power up the machine... this should clear the cmos password and/or CMOS settings. Power down. Put jumper back in original position and boot up.
Again... Just how is this solution inappropriate? Please call E-Machines and they will describe a procedure of similar fashion...
Good luck with that!
Wonderful!! Fixed my issue! Thank you very much!
Windows Password Breaker is to reset the forgotten Windows administrator password for you. Just prepare a CD/USB to reset password.
Firstly, use password prompt function on password locked computer
If you have set the prompt option when you set account password, it
may help you remember something about your forgotten computer password!
Secondly, reset computer password with default administrator account
Once we install Windows OS, there will be automatically generated an
"Administrator" account with blank password. Therefore, if we forgot
password on computer, we can have a try:
a. Boot system, and press Ctrl + Alt + Del keys twice when the Windows login screen comes up.
b. At the Classic Login window, input: Administrator and keep Password box null. Then press Enter key to login.
c. Recover computer password by: Control Panel - User Accounts.
Thirdly, find computer password with computer password reset disk
If we created this computer password reset disk before we forgot
password, we can opt for the disk to help us unlock password
efficiently.
a. Click OK and close the message box on the password incorrect prompt window.
b. Click "Reset Windows Password" and insert the password reset disk.
c. Do as the "Password Reset Wizard" to create a new password.
Fourthly, change computer password with Windows Installation Disc
Take computer Windows XP as example:
a. Start computer using Windows XP Setup CD.
b. When it asks to repair our current Windows installation, choose
"Accept" it and press "R" to run the repair. Then computer will begin
to repair our Windows and copy files to hard drive.
c. Setup will reboot system. Please don't press any key when there is "Press any key to continue..."
d. Now computer will do other tasks and there will be a progress bar
displayed. Please notice carefully the details shown at the bottom of
screen.
e. Once "Installing Devices" comes up, press keys: Shift+F10. Input:
nusrmgr.cpl and press Enter key at the Command Prompt window.
f. The same "User Accounts" window will display as it is in Control
Panel. Choose "Administrator account" and select any account listed to
change or remove your computer password.
Fifth, break computer password by DIY a password recovery disk
If the above four methods still can't help us reset lost computer
password, we can refer to this way now. DIY a password reset disk after
forgotten computer password means that we burn an .iso image file from
Windows password recovery software into a bootable CD/DVD/USB disk.
Now, take one of the top-rated Ainorsoft Windows Password Recovery
Corporation as example:
a. Download and install Ainorsoft Windows Password Recovery Corporation in any accessible computer (not from computer you want to unlock)
b. Burn an ISO image file to CD/DVD/USB Flash Drive
c. Set locked computer to boot from CD/DVD/USB Flash Drive and set the BIOS Setting for CD/DVD/USB Flash Drive.
d. Reset forgotten computer password to default Re123456.
The above ways on forgotten computer password reset are the collections of best bet for us to unlock lost computer password! So even if we forgot computer password, things will be OK soon!
source: http://www.windowspasswordrecovery.net/article/forgot-computer-password.html
The computer will not take f8 or anything else, it just go's to enter password to unlock the system. I have no Idea what that password is. I've never seen this before. When the computer comes on, it has, bios as f2, the the computer won't do anything with that either, it just comes up enter the password to unlock the system.
Everything has been helpful. I don't know if this is or not yet, buy I
appreciate all the help given.
which os do you use?
