Canon PowerShot SD1100 IS Digital Camera Logo
Posted on Mar 20, 2009
Viewing my videos
When i go to view my videos i have recorded.. They play through so fast its like its on fast forward.. Even when i put the setting on slow motion its still like its in fast foward.. Does anybody have any ideas i could try?
  • Anonymous Mar 27, 2009
    I have the same problem with my Canon Powershot..I am able to take videos, but when I go to view them it only lets me view them in fastfoward and with no sound! If you find a solution..please post it! Thanks!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
289
Points
I have good and bad news for you guys. the bad news is that you'll never beable to see those videos in the normal time frame again. but the good news is that there's nothing wrong with your camera. try turning the sd1100 on again in video mode. then press on the function/set button. now just set the capture mode back to standard. you've had it in time lapse. if this doesnt help, then iono.... lol good luck!
When I fast forward I can't view the video.
Some VCR's can't view tapes recorded on other machines. However you could try cleaning the video heads to see if that makes any differrance.
Video Camera Not Working
change your tape or charge your battery and mess with it a little bit try the different views or options theres a record view a view video when done and rewind and fast forward
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
Skipping ahead when viewing recorded programs
It sounds liek your remote control button is sticking inside a bit.
To test it, have it playing, and hide the remote under a cushion so it can't possibly send a signal to the main unit.
Sometimes the rubber buttons need cleaning underneath, even though they don't appear to be stuck down at all.
Its also possible that the remote is actually just going faulty emitting fake signals. I have a HiFi that turns on and starts the radio all on its own (spooky!!!). I found its the remote occasionally sends a radio-on signal about once a week to the HiFi :)
I just hide the remote now unless i'm using the thing.
16helpful
2answers
Video Playback in fast mode (canon ixus 80)
Oh my, sounds like you accidentally recorded in "Time Lapse" mode (one of the specialized video features of your camera). Unfortunately, there's no way to convert the already taken video back to "Standard" video with sound, I'm sorry. However, you'll obviously need to set your camera back to standard mode for future videos. Press the "Function" button while in video mode. Then press left/right to select "Standard" video.
Camera plays in fast forward-like speed
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
Cannot play tape.
Sometimes that happens to me too. What I do is just push play, then fast forward, and normally if you watch it, the picture starts to come back. Just keep fast forwarding until you can see all of the picture, and you should be fine.
SHR-1040 - rewind from end of footage??
I'm wondering if the firmware can be upgraded as that might be the easiest thing. My other thought was that putting the hard drive into a PC and trying to view the video might be a way to see it.
No playback on JVC GR-D72
It souunds like the problem is in the Vid-PC connection. I suggest you start by downloading the latest version of whatever software you have used to capture and view.
Also - uninstall any hardware in the PC that is used to capture (just remove from system device list) and then restart the PC and let it detect and re-install.
If you don't know how to do these steps, then you'll need geek help.
Recoding and viewing
sir , the lcd flap of the camera has been spoilr\ed due to this the image is not coming on lcd , only u have to take the image through view fider , lcd fpc has to be changed / repaire u can contact me also [email protected]
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
