This site shows a separate part for the strainer body, but I'm not sure it is separate.
Call them with your model number and they can tell you if it unscrews and sell you the repair part that you need.
Worse case, you might have to see if you can remove the entire pump casing and purchase that.
Gary
The bearings are likely failing and they are not open to allow for re-lubrication. You can replace them yourself or take the motor to a local electric motor repair shop to have it done for you. A shop will probably cost about $40 to $50 for parts and labor. You should also replace the seal at the same time. The cost for the seal is under $10 and the labor shouldn't change.
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off"by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
