I just downloaded my iTunes update to 11.0.3.42 and my EZ Vinyl/Tape Converter (7.4.0.0) no longer works with it. I get an error message that suggests I change the Compatibility to match my Windows operating system. Neither iTunes or EZ Vinyl has a Compatibility setting for Vista operating system. What do I do now?
Perhaps the error message is referring to the Windows compatibility setting. You will find details in the help and support section.
It is claimed it makes later Windows work with programmes designed for earlier versions of Windows. It has never worked for me but you might be lucky...
Yes it's painful... Manufactures and vendors FIX the items that have THE MOST complaints, but often build in NEW problems with devices that worked before!
TRY going back to a older version(s) first... ESPECIALLY true if your device worked BEFORE the latest update... HERE is a GREAT Site for you and others:
Old and New Software Version Downloads OldApps com
IF you need a older version of X program... you should find it there!
Anthony
SOURCE: EZ Vinyl Converter produces file that doesn't work
Try
Control panel
-Sounds - click on Speech and Audio Devices -
Click onSounds and Audio Devices. or if your in classic view -double click.
Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
SOURCE: No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
SOURCE: ez vinyl converter used to convert to itunes
reload your software Itunes went to 9 and it needs to be updated.
SOURCE: I am having a problem recording more than 1 track
I have the same problem and do not know the answer. Was searching here for an answer to my problem. Only a small part, 4 tracks in fact, about 5 minutes from a 30 minutes tape are imported to Itunes. where is the solution because it seemed the computer was recording the whole tape without problem. Where is the data gone. Can someone explain. Nico
