SOURCE: Husqvarna Prisma 980 decorative stitch cassettes don't work
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Kent
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
SOURCE: i have singer 1725 sewing
Hi, you can download the manual free at this address.
http://www.singerco.com/uploads/download/691_1725.pdf
Happy Sewing!
SOURCE: I have a Sapphire 835,and
Hi Loops on
the bottom of the fabric = inadequate top tension Here are
other causes for this problem, but they are more unusual and should be considered
only if the common remedies don't answer. If it's
the bottom thread, the bobbin isn't wound or loaded correctly, or it's the
wrong bobbin. Check to see the bobbin fits in the bobbin case properly. Don't
mess with the bobbin tension unless you have to. If the machine had been
working before and is not now, the problem is most likely not in the bobbin
tension. The adjustment range is really tiny, and it's easy to mess it up.If it
still loops after you redo the bobbin, you might also check the parts around
the bobbin. Clean up all the fuzz that had collected around the bobbin. Remove
all fragments of thread and fuzz with brush and vacuum (don't use compressed
air or canned air or blow -- it pushes fuzz farther into the machine where you
can't get to it.) Pay special attention to the area around the feed dogs and
the sewing hook area. Please get
back to us if you have further query or else please accept the solution. Thanks for
contacting fixya.com
Loops on top of the fabric = inadequate bottom tension. this is probably a
tension problem. there is a discrepancy between top and bobbin thread tension.
The looping is a too loose tension in the bobbin or too tight a tension on the
top thread. in either case, and regardless of cause, the two are out of synch.
Try adjusting bobbin tension according to your machine type. after adjusting
the bobbin tension sew on a piece of scrap. use a medium sized stitch. check
and adjust and test until you are satisfied. If the looping isn't severe,
adjust top string tension slightly looser.
Lubricate the machine according to the manual's instructions if the manual
describes using oil.
SOURCE: kenmore 100 stitch machine will not form stitches
it's probably time for the machine to be serviced
