Sorry, it 'WILL NOT' charge a 4G Nano on this Dock no matter which adapter you use!!
Clear Adapters have small numbers on them which relate to different iPods - A reference sheet relating to these numbers is enclosed with the Adapter Pack!
I have the same problem, my dock was broken, but I got round it instantly by plugging my ipod into the speaker via the headphone port on the ipod and into the audio in port on the speaker. When new, the speaker actually came with a spare lead as you can plug any mp3 player into it this way. The sound quality seems exactly the same and I dont have to throw away the speakers. If you have lost the lead you need a 3.5 mm male to male headphone lead, just pence in any electrical shop or amazon.
Hi, I have this problem and when I spoke to JBL techical support they told me that Apple have changed their software on the New Nano and the ipod touch and of course the iphone and regrettably the radial does not support S video for these products. I'm told it will work with first generation ipod classics. PS: i had to carefully cut off some of the plastic plug to make sure the connection goes all the way into the back of the radial
Get one of these to sole your problem. ipod change their charging circuit I found one at Walmart in the ipod accessories section. Its called the Passport home dock adapter. http://www.scosche.com/products/productID/1695
- this accessory supports charging for the iPhone 3G, iPod touch (Gen 2) and iPod nano (Gen4) with most iPod docking stations - Snaps into any iPod universal dock and accepts universal dock adapters
The JBL Onstage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adaptor. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adaptor. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried it on the new 5th generation nano and this seems to work.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Bit late! Just remove the four rubber feet underneath (self adhesive). Take out the four philips screws. It's a bit of a mess inside - you'll have to remove the connectors and some screws to get to the i-pod connector. You dont need to remove the button pcbs just the main board. The i-pod connector pcb is on the end of the grey ribbon cable connected to the main board (the button end of the unit).
I have had exactly the same problem having bought a JBL Radial Micro for my partner for Xmas for use with the Ipod Nano, i contacted JBL via their website and was advised to contact Harmen on 01707278100. I was advised that the new ipod nano (chromatic) would not charge on the JBL radial micro. They stated that this was due to Apple changing the charging pin in the new nano. I have since bought a JBL Stage III. I contacted Harmen before buying this and was advised that the Stage II would not work. Hope that this is of use.
