I was tring to add the laptop to a network domain. During the process, power failure occured ( due to battery removed by mistakely). When I tried to restart the machine, the machine always goes to restart mode after displaying a blue screen. I tried to restart in safe mode, last known good mode etc. But i get the following message
Check to be sure you have adequated disk space. If a drive is identified in the stop message, disable the driver or check with the manufacturer for driver updates. Try changing video adapters.
Check with your hardware vendor for any BIOS updates. Disable BIOS memory option such as caching or shadowing. If you need to use safe mode to remove or disable components, restart you computer, open F8 to select advance start-up options, and then select safe mode.
Stop ... Eror code.....
Please let me know how to fix this. I beleive BIOS memory need to be reset. But not getting option to do so, even in F2 mode.
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
Can you post the stop error for this? You need to press F8 like you are going into safe mode, but select the option to disable automatic reboot on error.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the
memory chips. Set the chip aside then try rebooting the computer.
If it boots, then you know the memory chip you set aside is bad so mark an x on
it with an ink pen. If it fails to boot then move the chip to the next
memory slot and try rebooting. If it fails take the chip out and set it
aside, then put the other chip in and try booting it in both slots. If it
boots, just to verify that the chip set aside is bad, mark an x on it and put
it into the open memory chip slot and try booting.
Diagnostic Lights
CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide.
To help you troubleshoot a problem, your computer has four lights
labeled "1," "2," "3," and "4"on the front or back panel. The lights can
be off or green. When the computer starts normally, the patterns or
codes on the lights change as the boot process completes. When the
computer starts normally, the patterns or codes on the lights change as
the boot process completes. If the POST portion of system boot completes
successfully, all four lights display solid green. If the computer
malfunctions during the POST process, the pattern displayed on the LEDs
may help identify where in the process the computer halted.
NOTE: The
orientation of the diagnostic lights may vary depending on the system
type. The diagnostic lights can appear either vertical or horizontal.
Suggested Resolution
The computer is in a normal "off" condition, or a possible pre-BIOS failure has occurred.
The diagnostic lights are not lit after the computer successfully boots to the operating system.
Plug the computer into a working electrical outlet and press the power button.
A possible BIOS failure has occurred; the computer is in the recovery mode.
Run the BIOS Recovery utility, wait for recovery completion, and then restart the computer.
A possible processor failure has occurred.
Reinstall the processor and restart the computer.
Memory modules are detected, but a memory failure has occurred.
I dont want to lose my data as well as I dont have restore partition on the laptop.
Is there any other solution to this problem ?
I tried to reset my Windows 8 machine and i got the following message There was a problem resetting your PC check for solutions after selecting the check for solutions option it takes me back to the start page
I'm having the same problem with the blue screen and told to disable BIOS yada yada nor have I a restore point but I've ended up re-installing windows so would have thought my PC would be clean, and why don't any of the pointless over priced programs I've paid for help with any of this?
