This looks like you are using a Microsoft Windows Server computer or operating system. The "SAM" file is your password registry file for all the users within your domain controller (also why it asks you for your Active Directory users file). If you are expecting this to be something on your Mac, you may want to double check what you are trying to do. You might be installing Windows Server over your Mac operating system, or you may be installing a Server edition (instead of a personal edition) into a virtual machine.
SOURCE: macbook pro lock up
Apple also makes a $79.00 program called iWork, which has word processing and spreadsheets and presentations.
SOURCE: Digital Audio out in MACBOOK PRO.
Connect external speakers, headphones, or optical digital audio equipment. The headphone / line output jack accommodates optical digital audio output, analog audio output with a 24-bit, 44.1-192 kHz D/A converter, digital audio output up to 24-bit stereo and 44.1-192 kHz sampling rate and supporting encoded digital audio output (AC3 and DTS). For analog headphone / line output a standard audio cable with 3.5mm metal plug should be used. For digital audio, a standard Toslink cable with a Toslink mini-plug adapter can be used.
You can find the Digital to Analog converted:
http://tinyurl.com/9ms8mv
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
As Verb75 says - you just need the right cable.
SOURCE: How do you turn off DOS mode on a 13" MacBook Pro?
Is this a trick question? There is no "DOS mode" on a MacBook Pro.
Do you have WIndows installed as part of Boot Camp, and your machine is booting into Windows? To boot back into the Mac, either use the Boot Camp control panel in Windows, or hold down the Option key after you hear the startup chime and select the OS X partition to boot from.
