I was trying to put in demo firmware and came out recovery (code 108)
it says
recovery (code 108)
no
repair disk
format disk
and i press no but istill coming th same thing
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code
(104) on it. This might work for other error codes too. These are the steps i
followed
* Use the computer for this
process that you always used for this archos Archos should be plugged in to Pc
before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the
format disk
* Wait until all done do not pick any option on
archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc
first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by
holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this
time it will start Update you will see the progress bar moving, wait until it
is all done, it will shut off. Turn it back on and your archos will be back to normal
if the white screen takes long time to come on then just press and hold the power button and TVLCD button at the same time that will take the device to that white screen with 3 options
Solution works fine for 605. Thanks.
Only problem is that it deletes all those little bits of software that allow you to play the various types of movie files, and I bet they won't let me redownload them, but will expect me to buy them again.
archos 605 160gb Recovery(code 108)
i was trying to put in demo firmware and came out recovery (code 108)
it says
recovery (code 108)
no
repair disk
format disk
and i press no but istill coming th same thing and it not show hard drive on PC. I can't bing firmware from cd to archos .
How can I do?
window.google_render_ad();
