Garmin nuvi 200W GPS Receiver Logo
Posted on Mar 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nuvi 255, no maps intstalled, shows unlocked in detailed info
Have a nuvi 255 that is registered and shows unlocked in detailed info, but shows no maps found error. tried to put on 2009 update and it says that is can't becuse the unit currently has no maps installed. YIKES, it is only 3 months old and worked fine in the beginning.
HELP
SHARCNET-USA
Level 3:
  • Garmin Master 2,130 Answers
  • Posted on Jul 17, 2009
SHARCNET-USA
Garmin Master
Level 3:
Answers
2130
Questions
Helped
782456
Points
4950
This error is caused by a corrupt or missing map unlock code. Please email me @ [email protected] and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
How do i reset my garmin nuvi 200w satnav it says no detailed maps found how can i reinstall them
Locate the reset button, located on the back of the device, in the lower left corner. Remove the sticker covering the button, and use a straightened paper clip to depress the tab.
To reinstall maps
Connect your Garmin Nuvi to your computer via USB cable. You can only update the maps through connecting to your computer.
Open the "myGarmin" website and sign in with your Garmin account. Make sure to sign in with the account that you've purchased the map updates on.
heres a link to the site;
http://my.garmin.com/mygarmin/login.htm.
Click the "myMaps" tab on the myGamrin dashboard. This will load a list of all of your purchased map upgrades.
Click the drop-down menu in the "Recent Map Purchases" section. Select your Garmin Nuvi from the list of devices.
Install the Garmin Communicator Plugin when prompted. This is required in order for the Garmin website to transfer the map files to your Gamrin software on your computer.
Download and install Garmin Express. This is the program that allows your computer to interact with your Garmin Nuvi.
Register your device in Garmin Express. If you haven't already registered your device, you'll be prompted to when you start Garmin Express. You'll need to register in order to update the maps.
Click the "Updates" tab in Garmin Express. This will show all of the available updates for your Nuvi, including the new map update you just purchased.
Click the "Show Details" option next to your Map Update. Click the "Install" button that appears. You will need to accept the agreement before the update installs.
Wait for the maps to download and install. Once you agree to the terms, the map update will begin downloading to Garmin Express, and will then be transferred to your Nuvi. This will likely take several minutes to complete.
Close Garmin Express and unplug the Nuvi when the update is complete. The Nuvi will reboot and begin installing the updated software on the device. This may take another couple of minutes.
If you weren't automatically prompted to install Garmin Express, you can download it from
http://software.garmin.com/en-US/express.html.
Need map updates for a nuvi 255 looked on garmin site, but model not listed
You need to have your satnav registered to update it. You can find details of how to register and update it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
1helpful
When it is plugged in only shows a picture and a picture of computer that shows system been connected to it.
Nuvi will show a picture of unit when plugged in to computer, its charging, connected this way is a slow charge.
You also use this way to update any maps or firmware for your unit.
If you have a new Nuvi.... and you are looking to set it up, you must first register to Garmin to unlock the maps its free.
Go to www.MyGarmin.com your unit will be detected and map unlocks will proceed
1helpful
My garmin nuvi 205 keeps telling my " No detailed maps found that support routing. The nuvi cannot be used without them."
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device at the bottom of this solution
To retrieve your unlock codes you must first register your satnav if you haven’t already done so.
To registe;
  • · Connect the satnav to your computer.
  • · Click on “myGarmin”
  • · Click on “Register Your Garmin Product” and follow the prompts
You’ll be asked to create a username and password. Write them down and keep them safe as you’ll need them anytime you want to update your maps.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
I have a Garmin Nuvi 250 and I am having trouble with its software. I have rebooted the device and reinstalled the original software. It keeps coming up with 'No detailed maps found that support routing....
Press tools, then press settings, then press map. The map name should be shown with a tick beside it. If it's not ticked press the map name to tick it. Then it should be ok.
The only other reason you should have this problem is if the map is locked. You can unlock it by going to www.garmin.com. Click on My Garmin, if you've already registered the sat nav. Click on maps and you'll get your unlock code there. If you haven't already registered it you'll need to do so now to get into My Garmin.
My garmin powers down while installin gnew maps.
There are 2 possible reasons for it to say there are no detailed map available. The most likely reason is that no map is selected. Press Tools, then Press Settings, then press Map and then Map Info. There should be a tick beside the name of the map installed on the satnav. If not press the map name to select it. A tick will appear at the side of the map.
The other reason is that the map may be locked. You'll need to go to My Garmin, and then Maps to get the unlock code.
1helpful
2answers
It says . cant unlock maps.
Follow this below
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
1helpful
I just purchased a Garmin nuvi 255, and the maps are inaccurate.
Just go to http://www.garmin.com There will be a registeration link. Yes I think that you will get a free mapupdate with your registeration at least they used to do that. You will need your unit serial number and model.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
